does anyone know how the newer trucks are equipped aka inverter apu's??? it looks like werner improved there trucks. unless those are the lease ones
werner trucks
Discussion in 'Werner' started by wifi_guru, Feb 22, 2024.
ok i called in and got the specs of there trucks looks like there's no apu but they do have inverters now wich is new
MSWS Thanks this. -
so i'll just idle the truck not my issues if it breaksMSWS and Speed_Drums Thank this.
I worked there in 2022 and they had inverters, but the truck was programmed to shut off if the outside temperature wasn't above or below a certain threshold. Fortunately, my truck was set to only read the temperature when it started up, so if the conditions to idle were met, it would keep running even if the temperature later went into shutdown range. My wife's hair dryer was pretty good at making sure that initial reading was always high enough to idle.TheLoadOut, Chicken wang, LoneRanger and 2 others Thank this.
Bic lighter works too. There's a little nub under the driver's side mirror. Light that rascal up and you'll be good to go.TheLoadOut, LoneRanger, wifi_guru and 1 other person Thank this.
are the white truck fleese trucks i remember werner used to run blue trucks
Both of mine were white but I really couldn't tell you much about them other than they were International LTs and they constantly gave me problems.wifi_guru Thanks this.
Current driver here, very few trucks have apus but we all have inverters. We can idle the truck if the temperature outside is cold or hot enough they also come with bunk heaters.
MSWS Thanks this. -
What's the mileage like these days?
I team im out monday 8am get back early Saturday. Miles can fluctuate between 4 and 5kMSWS Thanks this.
