Western Belt Trailer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mike216, Sep 23, 2021.
  1. BoxCarKidd
    BoxCarKidd Road Train Member
    4,567
    6,655
    Aug 26, 2014
    When I have seen lines cooked it was caused by the pump being left on while driving down the road. One had a bad air control switch that would not shut off properly.
    Nice looking equipment there. I am scratching my head with you. It will be interesting to see how the trailer does with a different truck.
  3. mike216
    mike216 Bobtail Member
    44
    13
    Dec 15, 2013
    Cordova,Md
    The motor seems to run the same has it did when the trailer was new. The hoses will heat up with no load on the trailer. The belt seems to be moving smooth with no binding.
    Goodysnap Thanks this.
  4. mike216
    44
    13
    Dec 15, 2013
    Cordova,Md
    Thanks.
  5. krupa530
    krupa530 Light Load Member
    296
    1,140
    Dec 3, 2014
    Orem, UT
    Have you called Western and asked them. They are a pretty stand up company, And I’m sure this has come up before for them.
  6. Cat sdp
    Cat sdp . .
    21,322
    76,372
    Apr 8, 2012
    Orion's Belt
    Is the belt slipping on the rollers……?
    Put a gun on the lines and get a temp (how hot is hot?) your Hyd man should’ve done that. Especially since your complaint was heat……
    small plastic line 5 years old dry rot maybe ?
  7. mike216
    44
    13
    Dec 15, 2013
    Cordova,Md
    I will ,Thanks
  8. mike216
    44
    13
    Dec 15, 2013
    Cordova,Md
    Ok ,Thanks
  9. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    Might check fittings where hoses connect truck to trailer. Quick connect or screw on style. Had one once go bad and burned up pump it stopped flow completely. I agree with heat generally caused by restricted flow assuming all things the same as they have always been otherwise.
  10. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Could the hydraulic oil be a problem? Get a sample of the oil tested, Is this the only unit that is having problems? Is there a filter in the system that could be almost plugged?
    lester Thanks this.
