What’s 12.7 max boost psi.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Heavy pressure trucking, Aug 3, 2021.
  1. Heavy pressure trucking
    Heavy pressure trucking Bobtail Member
    11
    4
    Nov 23, 2019
    I was pulling a dry van 32k pounds and my truck felt like load was 50k. Put a computer on truck and seen boost psi is max 20 psi that’s with foot to the floor. Is that to low for a 12.7. And computer said hp is only 430 when tag on engine says 470. I’m thinking company had truck turned down but I’m not sure. Any help will be greatly appreciated.
  3. 062
    062 Road Train Member
    6,332
    33,971
    Oct 20, 2013
    You need to put a mechanical gauge on to verify. I have a Cat that only shows 22psi on the ecm,but the mechanical 34-36psi.
    Magoo1968 Thanks this.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    430 detroit should be 25ish on the boost
