What am I missing?
Discussion in 'CB Radio Forum' started by wolverine11, Mar 31, 2016.
  1. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    At the Loves in North Platte NE talking to drivers on cb and talking about cbs, and it seems the number one problem is always Swr. A driver bought a Uniden pc 78 xl, 9 feet coax, 6ft firestick at a cb shop in Wells NV about 7 months ago. He said the last 2 weeks or so the antenna warning light started to come on so I checked his swr and it was 3+ , so I checked the base of his attenna to see if possibly the copper wire had broken, checked the coax connection at the attenna and radio, and even put my 5.5 ft Francis on and swr was still a 3+ ,and I get a 1.7 on my 2016 cascadia with that Francis ( he is driving 2016 cascadia with wilson mirror bracket mount). So with my limited knowledge I am at a loss I dont know where else to look, and also checked coax where he ran it in the door hinge to see if it was pinched and it wasnt. I advised him to hookup to factory attenna( actually talked to him 3 miles away) and he is going to stop at cb shop in altoona Ia or council bluffs and see what is causing sudden high swr. Anyone have any thoughts on what I might of missed.
  3. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    What was the SWR at channel 1 and 40?
    Could be a grounding issue. I'm just now starting to read about radios and learn about this myself but I have read that 9/10 times the issues come from ground plain problems or other antenna interference.
  4. wolverine11
    1,628
    1,234
    Apr 1, 2015
    It was 3+ on ch 1,20 and 40 and he said it has only been high that last couple of weeks so how does a attenna system develop a grounding issue just like that when for 7 months no problem unless attenna mount got some moisture in it or coax suddenly went bad, dont know looking for some ideas.
  5. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    I'm surprised the guy in Wells Nevada didn't sell the customer a 7 foot piece of RG58 along with the Firestik antenna. According to that moron last time I was in there he said that you must use 7 feet of cable with the Firestik antenna in order to get a good match on your truck. That same idiot also said that Wilson antennas cause mosfets to spontaneously self-destruct and that's why he only sells Firestik antennas. On a positive note regarding that guy, every radio that comes out of his shop sounded crystal clear but faded out quickly.
    Reason for edit: his customers are Mudducks but they sound crystal clear
    Blaskowitz Thanks this.
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    If an aluminum bracket is involved in the equation corrosion will develop especially during the winter months due to Salt exposure which will create a ground problem
  7. wolverine11
    1,628
    1,234
    Apr 1, 2015
    That was probably it then, it was definitely not a stainless steel mount and he did run alot of west coast team operation with CRST, guess I just didnt think it could happen that fast ( 7 months) because Im sure he bought that new with the rest of it. I told him also that he should get his radio retuned, he allowed the guy in Wells to install echo, poor mans talkback and if he turned the mic gain any higher than 12:00 it would squeal, leading me to believe that limiter was removed or maybe he just needs a noise canceling mic or have the talkback removed.
  8. wolverine11
    1,628
    1,234
    Apr 1, 2015
    And it never fails there is always at least one know it all that says that he sets his swr with his calibration knob everymorning, really didnt know it was that easy and all these years Ive been shortning or lengthning the whip.
    handlebar Thanks this.
  9. Ridgeline
    22,727
    123,495
    What are you missing?
    I guess that taking some sandpaper to the mount and the mirror may help.
    Maybe get some conductive gel too stick under the mount once everything is cleaned and use some ScotchKote to seal the area up.
    Oh and please don't recommend echo stuff, it makes everyone sound like crap.
  10. wolverine11
    1,628
    1,234
    Apr 1, 2015
    What gives you the impression I would recommend anyone using echo, I was trying to get some input as to why the swr would suddenly go higher like it did with that drivers setup.
  11. Ridgeline
    22,727
    123,495
    Sorry didn't word it well. I meant talk them out of that echo crap at all costs.
