What are some tips regarding the 14 hour rule?
Discussion in 'Questions From New Drivers' started by Jamar Weston, Jul 13, 2015.
  1. Jamar Weston
    Jamar Weston Bobtail Member
    31
    8
    Jun 28, 2015
    I heard of a way where you can extend the 14 clock how and why? I heard you have to do 8 hours in sleeper and 2 off duty does this sound familiar to any one?
    Pumpkin Oval Head Thanks this.
  3. haulhand
    haulhand Road Train Member
    There's 9 million threads about running a split sleeper you should do a search. With that said you've got the basics of it the 8 hour break must be all in the sleeper and the other break can be either sleeper or off duty. When you count your hours you count back to the end of your last break and subtract those from 11 and 14 and those are the hours you have left until your next break. Don't think of it as an extension of the 14 more as a pause. The two hour break still counts in your 14 tho.
  4. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    The need for allowable variances from the standard HOS rules are a rarity. Leave them for those well learned in maximizing legal hours. Before long you will be in that same group!
    Mikeeee
  5. FwL
    FwL Medium Load Member
    438
    331
    Aug 30, 2011
    Sandpoint, ID
    Any periiod of at least 8 hours but less than 10 hours spent in the sleeper does not count against your 14 hour clock.
    Once you hit 10 hours you reset the 14 hour clock.
    This rule comes into play when doing an 8/2 split but is true regardless of whether you take the 2 hour break or not.
    Imagine getting tied up at a repair shop for 8 or more hours but needing to make your delivery on time. That's a good time to know this rule.
    Another trick for protecting your 14 is to park overnight at the shipper/receiver. That way you don't start your clock until you're actually working rather than starting your clock at the truckstop, driving for an hour to the shipper and waiting another 2 hours to get loaded.
    Another thing to consider is the half hour break rule.
    You can't drive if 8 or more hours have passed since your last period of at least 30 minutes off duty.
    That means you gotta take a half hour break sometime during your shift. If you take it too early (less than 6 hours on duty) you might have to take a second one before you can use the remainder of your 14.
  6. USIT420
    USIT420 Light Load Member
    145
    49
    Apr 9, 2011
    Atlanta, GA
    Avoid split sleep unless it's an absolute necessity. As a previous poster said, only if it's the only option to make on-time delivery. If you're on paper logs and you screw up then you have a violation. If you're on electronic logs then it will keep up with it for you. Know your company's policy, some companies don't allow split sleeper, believe it or not, even though it's legal.
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    I manage the 14 hour clock by starting over.
  8. freebirdusa
    freebirdusa Light Load Member
    271
    133
    Oct 21, 2014
    Thomaston ga
    Good one! I run two qualcomms lol
  9. TLeaHeart
    TLeaHeart Road Train Member
    4,169
    2,614
    Apr 1, 2008
    casper, wy
    split sleeper does not increase the number of hours of driving time, only changes when you are legal to drive.
    It does not increase the 14 hour clock, just suspends it, for the 8 hours, and takes away from the next periods drive time.
    If you have used your 11 hours driving, and take an 8 hour sleeper berth, you still have zero hours to drive, until you complete the full 10 hours off duty/sleeper.
