What C.B. should I start off with?
Discussion in 'CB Radio Forum' started by NateS, Feb 1, 2024.
  1. NateS
    NateS Bobtail Member
    4
    Jan 30, 2024
    Hello everyone I was just curious about all the things I need to buy to have a complete C.B. set up. I’ve watched videos and stuff but figured I’d ask y’all which ones you’d prefer and what other equipment to buy with it to ensure the best quality
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Go grab a cobra 29 off the shelf and hook it up in the truck. That’ll get you what you need to do for now.
    flood, AteamDRIVER80, Numb and 2 others Thank this.
  4. NateS
    4
    Jan 30, 2024
    Thank you! I just wanted to hear from someone else before I purchased
    Crude Truckin' Thanks this.
  5. Diesel Dave
    9,654
    32,701
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on the Cobra 29.
    Crude Truckin' and NateS Thank this.
  6. Numb
    Numb Crusty Curmudgeon
    4,318
    10,255
    Jan 30, 2012
    Charlotte, N.Carolina
    X 3 on the Cobra 29. had 3 in last 35 yrs. lol
  7. homeskillet
    homeskillet Road Train Member
    6,317
    48,882
    Jun 1, 2013
    Dayton, OH
    X4 on Cobra 29.
    Hooked it up to the factory antenna on a 2018 Volvo VNL and I was able to listen and talk far enough to keep myself and the truck outta trouble.
  8. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Guess I'll be the negative one. Todays Cobra 29's are basically throw away radios. I've worked on the 25 and 29's and one of the biggest problem is that they develop an intermittent problem due to cold solder joints. It's like looking for a needle in a haystack and most CB shops aren't going to waste a few hours trying to fix it. Mainly it's cheaper just to sell you another cobra radio than to fix the old one.
    If you want the features of a cobra 29, then I would recommend the Uniden PC78LTX. Much better radio quality wise for around the same money.
    PC78LTX - Uniden CB Radio
    jdchet, lual, slim shady and 1 other person Thank this.
  9. BigJim63
    BigJim63 Light Load Member
    62
    61
    May 1, 2014
    Evansville In.
    The Road King rkcb classic is worth a look also. I have one and prefer it over my Cobra 29. It is pretty much the same as the Uniden 78ltx but cheaper.
  10. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Anyone AT6666. Single Skipshooter, drivers side. LMR240 coax or LMR240UF coax
    Diesel Dave Thanks this.
  11. Ridgeline
    22,720
    123,335
    Most radios today that are intended for CB band are the same, throwaways. The uniden is a good radio, but even better are older ones which do the same job without the expense.
    I bought a crap load of realistic radios last year for $25. I got them with another package of military and high-end radios that were going to go to the scrap yard. There had to be 60 of them - never counted, most of them are TRC-452 and Mini 40s. I asked some of the drivers if they cared what was put into the truck, and most said no, so off to my tech went a dozen of them to get aligned and serviced (no he did not replace the caps, they are fine). I had one problem radio out of the bunch that ended in a truck, that radio had a defective AGC transistor and that was it. The mini 40s are liked better than the 452s, it is a no-bs radio, with channel control, squelch, and volume, nothing else.
    mike5511 Thanks this.
