what c15 do i have??
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wtokhi, Apr 3, 2020.
  1. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    hello,
    i have an 2001 kenworth w900l with a c15 acert, i have no idea what type of c15 it is, i have some pretty good cat knowledge, i know its an acert bcs of the twin turbo and precooler set up, possibly MXS or BXS, but the valve cover just says c15, the truck originally came with a 6NZ but unfortunately it was swapped out before i bought it :( the parts all seem to come from different engines that fit each other but i have no idea, here are some pics that can help a more trained eye. i do have this part number off the front cover, 177-4153, also i know i could plug in a computer and see the serial number from the ecu but im not even sure this ecu is for this engine since so many things were changed out, thanks!
  3. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    I started reading thread and said to my self why the hell a accert in a 2001. Probably got a scrap motor out of a wrecked truck
  4. Dodsonf855
    Dodsonf855 Bobtail Member
    25
    22
    Mar 15, 2020
    South arkansas
    I was thinking the same thing.... a accept didn’t come factory in 01
    wtokhi and Chubby Fly Thank this.
  5. Chubby Fly
    569
    797
    Nov 25, 2019
    Delete the twins and do the single swap asap
    91B20H8 and wtokhi Thank this.
  6. wtokhi
    251
    115
    Nov 3, 2017
    yeah but im tryna find out if its a '04 acert or an '07, im in california and those years make a difference
  7. wtokhi
    251
    115
    Nov 3, 2017
    these acerts actually aint that bad, this ones got good power too
    Shawn2130 Thanks this.
  8. Chubby Fly
    569
    797
    Nov 25, 2019
    They have good power. Was just thinking longevity. The twins was to confirm to emissions standards
    Bean Jr. Thanks this.
  9. AModelCat
    165,237
    Look at the S/N stamped on the block. That'll tell ya.
    Pretty sure Cali would be a no go with either the MXS or BXS. Probably the only CAT you might be ok for Cali with would be an SDP.
  10. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Looks like a 6nz that someone just bolted twins on.
    Contrary to popular belief accert twins work very very well and support HP upgrades . Guy probably picked up used set twins off someone doing a single conversion.
    I only see 1 pass through harness on valve cover spacer plate. Looks like a 6nz to me.
  11. wtokhi
    251
    115
    Nov 3, 2017
    theres a lot of wiring just hanging, like for the coolant diverter valve and stuff, are there any other indicators that its still a 6nz?
