What coax do I need 2013 Peterbilt
Discussion in 'CB Radio Forum' started by FLHT, Aug 28, 2024.
  1. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    2013 Peterbilt has the dual antenna set up.
    I just want to go with one antenna and somebody has already been in there before me and cut coax.
    I assume that when I remove the drivers side antenna it will have the coax screwed into it.
    Is it mini coax with mini plug on one end and pl 259 on other ?
  3. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Run a new coax with new ends.
    handlebar Thanks this.
  4. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Get to studying on coax that fits your needs..Lotsa good and #### coax..Everyone will say "all you need is" and then tell you their fav..Make sure its 50 ohm for one antenna and 75 ohm if you stick with 2..
