What could have caused this.
Discussion in 'Experienced Truckers' Advice' started by LoneRanger, Jul 19, 2019.
  1. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    these steers Have 90k on them. What in the world would have caused this.
    I have centramatics on it.
    Any advise is appreciated.
    Lepton1 and singlescrewshaker Thank this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Cupping that bad means alignment, front end or suspension issues. Take it to a heavy duty truck shop capable of doing alingment work and find the source of you problem.
    It wont be too long before you expose the belt and in this hot summer pavement not much to turn them into bombs ready to tear your hood off. And drag you off the road at speed.
  4. Espressolane
    18,673
    117,021
    Shocks, alignment, tie rod ends, kingpins, bent wheel.
    86scotty, PE_T, InTooDeep and 5 others Thank this.
  5. HillbillyDeluxeTruck
    5,952
    30,449
    Mar 3, 2013
    San Antone
    All of the above.
    Those tires are bad. Like to the point that you should've caught the issue a lot sooner.
    86scotty, Bakerman, PE_T and 1 other person Thank this.
  6. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    I should have yes, but there was no issue that I could have spotted. The truck really was running hard last 2 weeks.
    Issue was discovered past couple of days and I waited until I got home to fix it as I don't trust these bs mechanics on the road.
    singlescrewshaker Thanks this.
  7. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    "Brand new"
    "90k on them"
    What everyone else said. It's cupping, likely a bad alignment. I take it your steering is shaking at 40-50 mph?
  8. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    Shocks are brand new,
    Yes around 40-50. Then normal at 60-65.
    My guess was centramatics failing because it happened out of no where, started 3 days ago approx.
    And when I say brand new meanin it was replaced 10 months ago and only have about 90k on it or less.
  9. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    Mine started doing the same, but only on the extreme outer edges.
    Was also told could be spring pads? But not sure if that's true..
    Wheel bearings played a part in mine. No shaking at any road speed. No pulling side to side either..
  10. WiggleWagon
    WiggleWagon Light Load Member
    232
    312
    Aug 17, 2016
    Parked At The Fuel Island
    What are you talking about? There's nothing wrong with that tire! (Says my former boss)
  11. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I once went home telling a boss like that call me when that thing is fixed. Or hand me one of them newer petes in the remuda you have in the far corner.
    Boss: HAYULNO. And you can imagine the distress he was experiencing with the thought of handing over a 90K tractor to his pets. But not to a ordinary driver in his fleet that does not do badly but nor outstanding either. Just average.
    7 months later that company imploded and that was the end of that.
