What do these switches do ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SilverBulletBand, Jul 1, 2020.
  1. SilverBulletBand
    SilverBulletBand Light Load Member
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    Referring to the 2 switches on the ends.
    I know they are for the tandem axle locking but how exactly do they work ?
    Why 2 different switches ? What's the difference ?
  3. Goodysnap
    Goodysnap Road Train Member
    3,728
    9,060
    Jul 12, 2017
    Left switch is diff lock or power divider.
    Right switch is axle lock.
    Thats the way I read it.
  4. Heavyd
    Heavyd Road Train Member
    7,797
    6,237
    Feb 4, 2009
    Yep, looks at where the little "X" is. Left is between axles to lock front and rear axles together. Right is in between both rear rear wheels to lock both wheels together so you don't get one wheel spinning.
    SilverBulletBand Thanks this.
  5. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    So the switch on the Right is like a Posi-Traction Lock in ??
  6. Tb0n3
    Tb0n3 Road Train Member
    4,657
    9,373
    Oct 5, 2012
    Earth
    Diff lock is a dangerous thing to play with. Activate it on pavement and you can do some damage by turning. It locks the axle solid so that both wheels turn at the same rate regardless of their path. Great for traction. The interaxle lock is the diff that takes input to one axle and transfers to the next. That's a lot more forgiving. Lock both together and you can spin all four duals.
  7. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    10-4 on that. I've had lots of 4x4s over the years. Just wasn't sure on the tandem operation.
    So on that, I take it the front axle of the tandem is the Primary drive axle and engaging the Interlock brings the Rear axle into sync with the Primary ?
  8. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    We go off road everyday entering new housing development construction sites. Here in TN, the soil is primary clay and after it rains, it's freaking mud disaster area.
    I've been activating both switches AFTER I leave the pavement. Then enter the mud zone. My trucks traction really kicks ### in the mud (would be better if my boss would replace the 2 LR tires....). When I get ready to go back on the pavement, I turn the switches off.
    Am I doing this right ?
  9. Tb0n3
    4,657
    9,373
    Oct 5, 2012
    Earth
    Yes.
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    That's right, just whatever you do make sure no tire are spinning when you turn them on, it'll grenade diffs and power dividers I've always been told.
    Hatt91 and SilverBulletBand Thank this.
  11. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    Good to know.
    Maybe my boss will buy a new truck "IF" the rear diffs just happen to "grenade" ! Lol ! J/K !
    Thank you for ya'lls input !
