What do you do when driver side door will not close?
Discussion in 'Experienced Truckers' Advice' started by A Bug, Dec 4, 2018.
  1. A Bug
    A Bug Heavy Load Member
    960
    1,984
    Mar 15, 2014
    Sevierville TN
    This seemed like it could have been a simple fix but I ended up having to drive to the International dealership to get the door fixed.
    I was in Casper Wy and the wind there was going nuts. Was trying to close the door but there was something in the wind that messed up the latch so that the door would not shut all the way. I had to strap the door down as far as it would close and luckily the dealership was only a few miles away.
    This is not the first time this happened on a windy day. Is there an easy fix for this kind of problem? Dealership had me out in about 20 minutes.
  3. ncdriver1
    ncdriver1 Road Train Member
    1,106
    1,252
    Dec 3, 2012
    You should have asked them what they did and had the tech show you.
    When my door latch gets sticky I hit it with some wd40 and open/close it a few times. Seems to do the trick.
  4. Chinatown
    Chinatown Road Train Member
    77,815
    184,845
    Aug 28, 2011
    Henderson, NV & Orient
    Could have used a seatbelt on it.
    Actually a tarp strap or bungee temporarily.
    What did the dealership do to fix the problem?
  5. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Dealer probably used what the other guy mentioned. Wd40
    That’ll be 90 bucks sir
    Rideandrepair and KB3MMX Thank this.
  6. A Bug
    960
    1,984
    Mar 15, 2014
    Sevierville TN
    Will be sure to bring along a bottle of that dw40, stuff works nice. II spend a lot of time in wy, hopefully that will be all it needs.
    Rideandrepair, BillStep and Chinatown Thank this.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,988
    19,046
    Nov 1, 2010
    Burnsville, MN
    'Something in the wind'...
    Maybe look for a twig or something in the latch next time?
    Rideandrepair Thanks this.
  8. Sirscrapntruckalot
    Flat head screw driver will also work. If the latch is being wonky.
    At lest in my experience.
    YMMV.
    Sirscrapntruckalot - No. - God when answering prayers.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Better fix it.
    Before it really gets cold enough to twist your door off it's frame and leak in air.
    BUMBACLADWAR, Rideandrepair and KB3MMX Thank this.
  10. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    May be out of adjustment. Check Nader bolt
    Rideandrepair and magoo68 Thank this.
  11. Ridgeline
    22,734
    123,590
    Did they just get the latch to close the door or did they actual fix the problem by replacing the latch?
    I would have them replace the latch, problem solved for the rest of the truck's life.
    Haven't heard that said in a long long time.
    cjb logistics and Rideandrepair Thank this.
