Anyone know what parameters the ecm uses to calculate % of engine load- I just discovered this in the data star today. I am trying to watch how hard I run the old girl, having a 1mm 600hp file in it, (it`s a 475 MBN) but still running the stock turbo. My pyro has just started being erratic, so I can`t go by that, and my boost seems to top out at 34 (read one time that`s as high as it will read). Thinking I should be able to run it by the engine load readout as long as I don`t go too high. Thoughts*
What is % of engine load readout
Discussion in 'Western Star Forum' started by 04 LowMax, Jan 29, 2014.
Great question .....Mine was at 29% , but I have no clue how they get that #.
It`s an ongoing variable readout, changes constantly, not quite sure what you mean by it was at 29%.
Not sure either, nit sitting here @ idle its fluctuating between 8-12%
Sent from my RM-845_nam_vzw_100 using Board Express -
Not sure it's listed on the ECM download as engine load factor as a % mine was actually like 34%. I just looked it up.
I tried to copy that page.... But messed it up
I guess that's the life time average? -
I'll check it out in the morning and post my crusing%
It measures acc. pedal position, rpm level, and how hard the ECM has to adjust fuel to keep the engine at that certain RPM to get a % load value.
My 14.0 that I tuned makes about 45ish sometimes 50 if I get on it... Should be making more than that if its truly making 600hp. Does it only top out at 34 even when you're fully loaded?Last edited: Jan 30, 2014
Yes, but I read one time that this was a maximum value that it could display.. I think it might have been underpsi who wrote it. Something to do with the ecm. It could be putting more boost, but not showing it. Also, I am still running the small stock turbo, which would limit boost. Haven't quite felt ready to
dump $2400 into a new turbo. Also, I guess maybe I'm a little concerned that if I did upgrade the turbo, and the boost psi, is there a possibility of doing damage by putting more strain on this engine, with some 26,000 hrs. on it now? I don't know the previous rebuild history if any, of it. I have had it for only 3 and 1/2 years.
