what is that air line for?
Discussion in 'Freightliner Forum' started by ptwn1, Nov 4, 2014.
  1. ptwn1
    ptwn1 Light Load Member
    94
    11
    Oct 4, 2012
    hello i have a air line leak under the radio it has a whole bunch of other air lines under there what are they for?
    i have a 2002 century
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    It controls the way air blows out of vents, floor def. if you move lever to a different poss. it should stop leaking at good one, then find the one its leaking from small rubber air pod that controls flap to turn air from one to another flap door?
  4. bad-luck
    bad-luck Road Train Member
    3,442
    6,348
    Nov 16, 2013
    Baltimore, Maryland
    Underneath the radio behind the trash can the air manifold. The sensors and for the cruise control, parking break and sevwral othera. The parking break or cruise control usually go bad. They are cheep but you need a a special socket to remove and replace
  5. Jimmbuds
    Jimmbuds Medium Load Member
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Yup I would say the air manifold also is what you are seeing. My manifold went bad on me when I was replacing one of the switches. I tried loosening the switch that was leaking and the metal insert started spinning. If I were you I would buy a replacement and have it available just in case. It could be enough to ground you on the side of the road if you were to have a leak.
  6. ptwn1
    94
    11
    Oct 4, 2012
    yea air is leaking out the manifold jimmbuds around the switch with the metal piece on like a pipe or somthing. what is that for cause everything still works in the truck
  7. Jimmbuds
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Each switch controls something different. There is like 4 or 5 different designs of the manifold. It really all depends, do you have a switch leaking or is the manifold itself leaking? If the manifold is leaking I would recommend replacing it (cheap $125), I wouldn't recommend trying to doctor it up. If you have a switch leaking well that is a cheap easy fix. If you have to replace the manifold I would recommend getting some paint pens from the "arts and crafts" department at your local supermarket and color code everything so it makes installation that much easier. Good luck
    mgrantes Thanks this.
  8. Bigman58
    Bigman58 Light Load Member
    60
    11
    Feb 12, 2014
    It replaced my air manifold and had a hell of a time getting the new lines to not leak.
    Had to eventually take it to a mechanic. The air lines have to be perfectly straight or they will leak. I'm afraid when I have to go into the dash to repair something and just bump any air line and creating a new leak.
