What is the purpose?
Discussion in 'Flatbed Trucking Forum' started by Coloradoman, Nov 18, 2018.
  1. Coloradoman
    Coloradoman Light Load Member
    115
    65
    Aug 25, 2018
    Jesup, GA
    So right now I'm just renting a flatbed from the person I am leased to, supposedly in a couple of weeks i might get a step deck instead( I like step a little more). The plan sense the beginning is to get into big then move to heavy. I have done some oversize but nothing to write home about. Guess my question is, with a multi axle step, what is the purpose? You still cant go over 80k, is it just weight distribution? Or can you actually pull more?. Also when I go buy my own trailer I have seen the stretch deck step deck, not to sure if it would really be beneficial to get that one though. So are multi axles worth it? Can you pull more?
  3. kylefitzy
    kylefitzy Road Train Member
    4,753
    19,806
    Aug 12, 2007
    Kansas city,Mo
    You can Permit more on a tri axle step then a spread or a tandem. You can still only go to 80k, generally, but with a tri axle step you’re not shooting for general fright.
  4. abyliks
    abyliks Road Train Member
    4,141
    9,754
    May 2, 2010
    ludlow MA
    Depends on your state, up here in the north east NY, VT, NH all allow 99,000+ if you have the extra axle, (MA and RI allow 99 on 5)
    Coloradoman Thanks this.
  5. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Yoi can do 120k in Missouri
  6. Coloradoman
    115
    65
    Aug 25, 2018
    Jesup, GA
    I'm in colorado, but run everywhere. I have been trying to learn stuff like what you said, but seems like google gives you 100 different answers that all say different stuff lol.
  7. Espressolane
    18,717
    117,367
    Need to look in the front of your atlas, it will have all the state info as well as a listing for the states web site.
    The state site should cover the most common questions.
    Lepton1 and Coloradoman Thank this.
  8. Rontonio
    Rontonio Road Train Member
    6,494
    47,969
    Aug 9, 2009
    Need to know whether you re talking about divisible load versus non-divisible loads...
    Tug Toy, FoolsErrand, stwik and 4 others Thank this.
  9. Coloradoman
    115
    65
    Aug 25, 2018
    Jesup, GA
    Both? Probably more so non divisible.
    Oxbow Thanks this.
  10. TripleSix
    133,525
    I was lost at “multi axle. A multi axle trailer is a trailer that you will need a doubles endorsement to pull. You’re probably referring to a 3 axle step, as there’s no such thing as a multi axle stretch.
    Tug Toy, Rugerfan, stwik and 2 others Thank this.
  11. Rontonio
    6,494
    47,969
    Aug 9, 2009
    Mostly the wrong answer
    Generally speaking you cannot permit for weight for Divisible loads such as lumber or cars or flour. There are some states that will permit divisible loads over 80k gross but not generally. Yes I know in the northwest with the right set up you can 105500 or in Michigan you can to some other gross like 150k but you can’t take a 15500 load from WA to MI.
    If the load is non-divisible the you can typically permit in each state you travel through based on your axle configured spacing and the states regulations for permits.
    I would suggest you do a lot more research and reading before you do anything else.
    Tug Toy, FoolsErrand, SL3406 and 5 others Thank this.
