What is this air brake component?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by careycal64, Apr 24, 2022.
  1. careycal64
    careycal64 Bobtail Member
    11
    7
    Feb 11, 2022
    After two spray bottles of soapy water, I finally found my air leak. It's coming from the bottom center of the component pictured. In case it it not pictured, it is located between the frames in front of my single axle. It's three units. The center unit is the one leaking air. The center unit has a big air hose going into it and the two side units have hoses coming out and going to the rear air brakes. Here are my questions:
    1. What is it?
    2. Can I buy a rebuild kit for it?
    3. Where can I buy a rebuild kit?
    4. If I have to buy a new one, where can I get that?
    Truck is 2011 Volvo VNM single axle D11 Volvo engine.
  3. Big Road Skateboard
    7,098
    40,288
    May 2, 2021
    ABS Valve with modulator valves on each side. Don't assume it's bad if it's leaking. Most any dealer or aftermarket supplier can get them.
    AModelCat Thanks this.
  4. careycal64
    11
    7
    Feb 11, 2022
    Thanks! I hope someone can tell me how to fix it without replacing it. I would bet these puppies are above my pay grade.
    Big Road Skateboard Thanks this.
  5. Big Road Skateboard
    7,098
    40,288
    May 2, 2021
  6. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
  7. careycal64
    11
    7
    Feb 11, 2022
    Well. That's not too bad. Is that new OEM, refurb or China? Probably the best idea is to replace it. But it seems like overkill when it is probably just a gasket or an o-ring. This is my first personally owned semi. I've been doing my own mechanicking for years but never on a semi. I'm all ears on where to go for parts. The places I've found seem limited in both information and even the parts themselves. I guess I could just contact a Volvo dealer. There's one in Medford. Tec Equipment I think.
    Thanks for the info, xsetra.
  8. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Does it leak air all the time? Or when does it leak air?
  9. xsetra
    5,196
    7,147
    Aug 21, 2011
    When mine leaked constant. I replaced all three pieces. You can replace each of the 3 pieces
  10. AModelCat
    164,695
    Does it only leak when the park brake is released? If it does, good chance it could be a brake chamber bypassing internally.
    D.Tibbitt, xsetra, spsauerland and 3 others Thank this.
  11. careycal64
    11
    7
    Feb 11, 2022
    With the parking brake on, idling at 1,000 rpm it leaks all the time. It leaks while the air is coming up and still in the red zone. There's a round socket or collar on the bottom center about 1.5 to 2 inch diameter. Inside this there is another smaller collar with a rubber disk dust cover. If you fold that down you can see a filter screen so this must be an overflow valve. It doesn't leak. The leak is coming from the inner rim of the larger collar around the large circlip holding it all in place.
    I think MLC Adventures will turn out to be right and I just need to replace it. I hope xsetra's price estimates are close.
    Two more pics. One before spraying soapy water, one after.
    D.Tibbitt and Dave_in_AZ Thank this.
