What is this called?
Discussion in 'Ask An Owner Operator' started by Ikamob01, Dec 3, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    what is this trailer part called and where can I buy them from? See example: The first aluminum metal on the floor.
    Boondock Thanks this.
  3. 86scotty
    86scotty Road Train Member
    4,744
    13,014
    Aug 27, 2017
    Appalachia
    You mean the bottom half of the pic showing the diamond plate 'plate' on the floor? That's built with about every trailer out there. Go to any metal supplier and get a piece of diamond plate.
  4. Ikamob01
    314
    195
    Dec 4, 2021
    yeah. I know, mine is damage. so that's just a diamond plate?
  5. 86scotty
    4,744
    13,014
    Aug 27, 2017
    Appalachia
    Go to any trailer shop and show them yours and see what they say. I couldn't tell you what yours is. They can.
    Flat Earth Trucker and Boondock Thank this.
  6. Rideandrepair
    17,582
    56,950
    Aug 8, 2015
    It’s steel. 1/8” thick I believe. Had a new one put on my last trailer. They stood it up, stitch welded it, laid it down, drilled new holes and installed new screws. I then had them weld it all the way across. Better than new. Original plate was thinner, and only 2’. New one was 4’. Much better.
    JoeyJunk, Siinman, Ikamob01 and 2 others Thank this.
  7. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    Lowes/Home Depot sell diamond plates in the hardware section. they won't be as large as what is in your picture, but you can buy a a couple of pieces cheaper than at a trailer shop, as they get thiers from a vendor, and they will mark it up.
    you can also try just about any welding shop, metal shop too, like an HVAC supplier...
    Ikamob01, Boondock and Rideandrepair Thank this.
  8. OLDSKOOLERnWV
    19,287
    291,622
    Pretty sure I seen aluminum diamond plate at Menards the other day. Larger than I’ve seen at Lowe’s….
  9. rollin coal
    rollin coal Road Train Member
    13,713
    28,236
    Mar 29, 2008
    TN
    Can probably get it cheaper from a local machine shop than Lowe's, Home Depot etc
  10. INRUT
    INRUT Medium Load Member
    560
    2,042
    Aug 21, 2016
    Diamond plate floor plate.
    Ikamob01 Thanks this.
  11. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    tread plate call any metal supplier in your area.
    JoeyJunk Thanks this.
