what is this sound
Discussion in 'Freightliner Forum' started by shatteredsquare, Nov 29, 2020.
  1. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    coming from behind the fuel filters
  3. MACK E-6
    50,139
    239,521
    I assume you’re referring to the noise that’s occuring roughly every 2 seconds?
    Rideandrepair Thanks this.
  4. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    yeah that pulsing click sound, it's linked to RPMs, higher RPMs and it picks up the cadence. pretty sure something fuel system related, it's coming from the Bosch thing behind fuel filters. no fuel issues at all, MPG fine, timing fine, power fine. just a whole lot of clicking...
  5. 86scotty
    86scotty Road Train Member
    4,728
    12,990
    Aug 27, 2017
    Appalachia
    I've heard that before on occasion. I don't think it's a problem. Maybe it's the DEF system pulsing fluid?
    Rideandrepair and D.Tibbitt Thank this.
  6. D.Tibbitt
    157,290
    This must be a detroit. I had a freightliner with detroit that did this non stop..
  7. MACK E-6
    50,139
    239,521
    I think he said in another thread it’s a DD13.
  8. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
  9. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    O.K. Now we are getting somewhere! What you have is an injector(s) that have a cracked seat face. Where the injector meets the injector cup face there is a copper washer. Under the washer the injector nozzle seat has a crack. I have dealt with this "chirping" many times. Detroit solution is to replace all 6 injectors since it will probably eventually happen to all of them anyway. Mucho $$, so you can pull and inspect, sometimes magnifying class is needed, and replace only defective ones. Good news is Bosch identified problem a while ago and new injectors don't have this problem.
    magoo68, xsetra, Rideandrepair and 3 others Thank this.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    My 2016 and 2018 have both made this sound since new.
  11. Oscar the KW
    12,247
    28,120
    May 19, 2011
    This is the sound I think you are referring to, and would make since. A cracked face on an injector will put air back into the fuel system. The sound I hear in the op’s post is the fuel quantity control valve doing its thing.
    D.Tibbitt Thanks this.
