What paperwork do I need as a dispatcher?
Discussion in 'Ask An Owner Operator' started by newola, Dec 14, 2019.
  1. newola
    newola Bobtail Member
    6
    4
    Dec 13, 2019
    I don't really understand the full cycle process of dispatching
    D.Tibbitt Thanks this.
  3. Ridgeline
    22,815
    125,530
    it isn't rocket science, there isn't much to it.
    I don't see where there is a cycle to it, you look at the load that comes into your screen, you call the driver and give it to them. Once it is done, they send in the paper work.
    Flat Earth Trucker and D.Tibbitt Thank this.
  4. newola
    6
    4
    Dec 13, 2019
    Oh see I thought the paperwork happens before, the carrier packet just really confused me
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Driver gets told where to load, what to get and when to deliver.
    Everything else refer back to the dispatcher.
    God forbid the dispatcher needs any of that paperwork now. Its all computer.
  6. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    The packet does happen first.
    PE_T Thanks this.
  7. PE_T
    PE_T Road Train Member
    I’m not sure if I’m understanding. First you find the load on the loadboard that you’re interested in. Then you call the number or sometimes respond via email. The broker will give you more information about the load, including how much they will pay. Once you agreed to the rate, then you fill out the carrier packet if you are not signed up with them. The broker will process the packet and then email you the rate con. Usually you have to sign the rate con and email it back, or sometimes you can accept the rate con right from a link in the email.
    D.Tibbitt and adayrider Thank this.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    power of attorney maybe )))))))
    PE_T and D.Tibbitt Thank this.
  9. MagicMan22
    MagicMan22 Bobtail Member
    29
    19
    Dec 15, 2019
    100% correct. Also know that dealing with brokers on the load board is like a flea market. Only accept the rate offered if you HAVE to get out of where you are. Otherwise negotiate.
    feldsforever and PE_T Thank this.
