What shouldmy fuel pressue be at?
Discussion in 'Peterbilt Forum' started by irishluck09, Mar 26, 2020.
  1. irishluck09
    irishluck09 Light Load Member
    295
    180
    Nov 24, 2019
    1996 peterbilt 378 with 3406e
    Past few days my truck hs been bogging down at about 1700-2000 rpm. Cant get above 50mph. Assuming its my fuel filters.
    If my fuel psi gauge is working right, at idle it sits at about 32psi. High idle, 45psi. And when driving under load, about 5psi. Assuming 5 psi is a bit low right?
    stillwurkin Thanks this.
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    Not sure what the spec is, but 5psi isn’t right. You need to hook up another gauge to get a good reading. My guess is factory is 50-70 psi.
    @spsauerland @pushbroom can give you the right number.
    pushbroom Thanks this.
  4. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Change fuel filters to start. Restriction guage reads off primary filter. My guage from 2 to 8 is in the green. But should run at appprx 5 give or take. 5 to 6 even when pulling. How long since you changed filters?
  5. irishluck09
    295
    180
    Nov 24, 2019
    I just bought the truck on November. I havent changed and no idea when the last owner did it.
    This is a picture of my gauge at idle
  6. pushbroom
    pushbroom Road Train Member
    1,788
    7,397
    Sep 1, 2012
    If its reading correctly is way too low.
    I would start by verifying it with another guage first. 75psi minimum idling and 90psi cruising speed or around there.
    spsauerland and 062 Thank this.
  7. irishluck09
    295
    180
    Nov 24, 2019
    Well i went ahead and changed out the fuel filter (the screened one) which was just covered in dirt. So assuming that wasmy issue.
    Now i jusycant get the truck started. Been trying to prime with the pump. Used 2 cans of starter fluid and it just wont stay running by itself.
    Is there a trick im missing here? Both filters are full of diesel
  8. 062
    6,329
    33,969
    Oct 20, 2013
    Do you have a way to put air in fuel tank?
  9. irishluck09
    295
    180
    Nov 24, 2019
    Unfortunately no. Shes being towed
  10. irishluck09
    295
    180
    Nov 24, 2019
    So come to find out, it was my lift pump that went bad. Put new one on and this truck has never run so good. 75psi idle. 90 under load. Even went from 3.5mpg to 5.5mpg
    pushbroom and 062 Thank this.
  11. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Mine works just the opposite way. It measures restriction, I guess, and have only seen it in the red one time and I changed the filters. I really want more gauges in this truck (egt, fuel pressure, maybe a couple others) but there isn't any place to put them. Not to mention I might or might not be smart enough to install them. 15861334856055809494049113770555.jpg
