What speed to downshift 10 speed transmission?
Discussion in 'Questions From New Drivers' started by Shaner.STL, Jan 23, 2019.
  1. Shaner.STL
    Shaner.STL Light Load Member
    63
    26
    Jul 26, 2017
    So I passed my CDL test and I’m finished w the trainer thank god ha. Thanks for all the tips and insight. I did want to post the speeds I was using to downshift at in case someone else comes along w the same question. I spoke with another trainer at work and he has his students use the formula below until they get used to just changing gears by the sound of the engine. Like you guys mention this can change based on the truck you’re driving but it provides a guideline at least.
    Downshifting:
    9th- 50-45 mph
    8th- 40-35 mph
    7th- 30-25 mph
    6- 20-18 mph
    5- 15-13 mph
    4- 10 mph
    Thanks again guys and hopefully this helps someone else out down the line when they start off.
  3. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    It’s really more of an RPM thing than a speed thing provided you’re not a total retard and aren’t trying to shift from first to 8th
  4. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,651
    Aug 28, 2009
    Airlie Beach QLd
    Sounds like you don't have a very good instructor don't know why he keeps yelling at you if your changing gears and there going in, why should he make a big fuss about it sounds like he's nit picking to me.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,062
    Nov 18, 2014
    Land of local
    Most fleet spec'd trucks that formula works just fine. Or remember this, a 10 speed is roughly 400 rpm between gears. 5th to 6th in my exp has been a pretty quick shift compared to the rest
  6. DualsThatTouch
    DualsThatTouch Bobtail Member
    27
    37
    Dec 9, 2018
    Illinois
    I just got out of school , we trained in peterbilts with 10 speed eaton, there were 3 trucks all pretty much identical but all felt a little different. I find it interesting that none of our trainers talked about your speedometer speed and shifting. It was all about engine speed. We were taught there were ~350-400rpm between gears and were taught to double clutch and upshift at 1500rpm. To single down, we were taught to take get the rpms down to 1000 clutch out of gear and rev up to 1500 rpm and clutch into lower gear. For double downshifts they taught us to get rpms down to ~800 then rev up to 1500rpm. It worked great for me, but it was a little tricky when you missed a gear especially going up or down hill to get back into gear, then it helps to have the speed references memorized to get back into gear. Our trainers were great and never yelled at us, if they did, i might have to stop and talk to them and let them know it does nothing but make things worse if you yell, theres already enough pressure, starting out we all want to learn as quickly as possible.
  7. VIDEODROME
    VIDEODROME Road Train Member
    1,487
    1,297
    Jun 7, 2007
    angola, in
  8. Shaner.STL
    63
    26
    Jul 26, 2017
    Just glad I'm done with that part of the training. It was a rough time but it helped me pass the cdl so it's all good now. Yeah, when I downshifting using those speeds I was looking at my rpm's as well. It worked out well on both parts bc I could ref the speed and it pretty much lined up with being at around 1000 rpm's when I clutched to neutral and then bumped it up to 1500 rpms. He also wanted me to bump the rpm's up when I was upshifting which I found was messing me up bc I would shift up around 1500 rpm's bump the accelerator and then it would be at 1700 rpms or so.... then I'd have to wait for it to get in the proper range to shift up. I just stopped doing that and my upshifting became a lot smoother.
