What steps to take in this situation
Discussion in 'Experienced Truckers' Advice' started by Jock Itch Kills, Oct 21, 2022.
  1. Jock Itch Kills
    Jock Itch Kills Bobtail Member
    A driver I know just texted me. He’s at a standstill.
    In a truckstop parking lot he text that he has no lights, truck won’t start. Won’t turn over a bit.
    If you’re in this situation what steps do you take. What do you check first and then second and what next.
    I got some ideas but so far he’s still dead in the water.
  3. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    Check the batteries connections. Company Driver? Call the repair shop.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Use the jumper cables in your side to hook up to 1st driver you can see that is awake?
    kylefitzy Thanks this.
  5. Casper88
    Casper88 Bobtail Member
    28
    159
    Feb 21, 2019
    Chicago
    If the truck has a battery cutoff switch make sure it didn't get flipped.
    tscottme, The_vett, Woodys and 2 others Thank this.
  6. TripleSix
    133,644
    2nd this.
    In my mind, NO LIGHTS mean that the dash lights aren’t even illuminated (correct me if this isn’t the case). From overnight??? What would kill the batteries from starting the day before to completely dead?
    Headlights left on, fridge, alternator was not charging and the driver didn’t notice.
    Check the date of the batteries. If they are 3-4 years old, I’d buy a new set. There’s no point in trying to jump old batteries. Should fire right up. Get that alternator tested too.
    Luck in battle.
  7. buzzarddriver
    3,849
    11,674
    Feb 1, 2011
    Dallas, TX
    Exit the truck, scratch your head, then kick the driver's side front tire.
    If that don't fix it, call for road service.
  8. Joyce's Volvo
    Joyce's Volvo Light Load Member
    116
    153
    Jun 28, 2016
    I’ve had 1 of 3 to go bad ( hooked in parallel) the bad one pulled the other two down, it could be the problem. It’s the pits when you’re out on the road,cold weather will tell you if you got a weak battery, check for bad connections or a disconnect switch first, possible try to get a charge on each battery after you unhook them ( taking off the parallel lines) using a battery tester will tell you if1 or more is bad. I change all batteries every 24 to 30 months on my otr truck and exchange them with the local truck or equipment. It saves me time and $ .
    blairandgretchen and cke Thank this.
