What style caps are these
Discussion in 'Flatbed Trucking Forum' started by hazzmatt89, Jun 8, 2025.
  1. hazzmatt89
    hazzmatt89 Light Load Member
    64
    56
    Oct 3, 2023
    Looking at a trailer to possibly buy and these are the caps over the hubs in the back, I’m only familiar with the versions where you have a clear cap and a plug you pull out and fill with oil.
    Trailer is a 2015 Fontaine velocity
  3. kwswan
    kwswan Road Train Member
    2,028
    11,084
    Jul 26, 2009
    mcminnville,tn.
    Grease filled hub instead of oil.
    cke, Oxbow, MACK E-6 and 6 others Thank this.
  4. AModelCat
    164,668
    Probably a grease packed wheel bearing if it uses solid caps like that.
    cke, Oxbow, MACK E-6 and 5 others Thank this.
  5. Big Road Skateboard
    7,098
    40,282
    May 2, 2021
    It's a grease filled, or semi fluid grease filled, Hendrickson hub it appears
    cke, Oxbow, MACK E-6 and 3 others Thank this.
  6. hazzmatt89
    64
    56
    Oct 3, 2023
    Ok thank you, are those any different bs the other ones is regards to quality? Trailers been sitting a year and went and looked it over today seemed to be in good shape minus tires and air bags look dry rotted with animal nestings all around them
    cke Thanks this.
  7. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,014
    2,086
    Dec 15, 2021
    I have a 2023 Fontaine,they use only Chevron synthetic grease.The decals on the trailer say maintenance free for 5 years.
    You're supposed to call Fontaine before you take one of the caps off.You only need to jack the axle up and check if they're spinning smoothly and don't have any play in the bearings.
    Friend and CAXPT Thank this.
  8. hazzmatt89
    64
    56
    Oct 3, 2023
    If this trailer has been sitting for two years and I’m considering buying it it’s a nice trailer but have my concerns since it has been parked for two years. Would I need to re pack it with grease? Brakes on the trailer all appear to be plenty of life left but I haven’t hooked a truck up to it. Guy still hasn’t sold it but came down on price
    cke and Friend Thank this.
