What test needed
Discussion in 'Questions From New Drivers' started by Rasco, Sep 2, 2018.
  1. Rasco
    Rasco Bobtail Member
    I currently have my class b with air break endorsement...what test will I have to take to get my class a
  3. WesternPlains
    6,369
    57,406
    Sep 1, 2017
    Rapid City, SD
  4. Hatt91
    Hatt91 Light Load Member
    153
    352
    May 18, 2018
    The ‘class a test’. If you want to drive a tractor trailer, then you also have to pass the ‘combination vehicle test’.
  5. brian991219
    brian991219 Road Train Member
    3,025
    6,217
    Aug 10, 2013
    Lords Valley, PA
    General knowledge for class A learner permit, then you will do the pre-trip, basic control skill and road test in a class A representative vehicle. If you want a full unrestricted class A it must be a 5th wheel type hitch, if it is a "bumper pull" type pull-behind ball or pintle hitch you will get a truck trailer only restriction.
    Since you already have air brake restriction removed you will not need to take the air brake knowledge, but if you test in a class A with air brakes you will have to do the air brake portion of the pre-trip including the 3 step brake check.
  6. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Combination and air brake tests
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You make sure it's a full blood 5th wheel tractor trailer WITH A MANUAL TRANSMISSION. NOT A AUTO.
    State will slap you with a restriction against Manuals if you show up with a Automatic Tractor trailer.
