Thank you guys for helping me with my questions. I have another question.....I have a 2007 Columbia/freightliner with Detroit engine 900,000 miles and the transmission is a meritor 10 sp. I was having problems with this transmission so I have not other choice than to fix it or put a new/rebuilt transmission. My question is: what would be the best alternative to fix it? (2,500) or to put a rebuilt eaton fuller? 13sp or 18sp (5,000 to 6,000). Which transmission will be a better choice for this engine? I haul light and heavy loads and most of the time is in the western states.
thank you for you help.
what transmission is better?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chimbotano, Sep 11, 2013.
I personally would stay away from meritor, unless your very heavy and off road 13 will do just fine, if your over 100,000 and/or off road you might need 18.
chimbotano Thanks this. -
I'm willing to bet you have an overdrive 10 speed. If so find out the final drive ratio. If it is very close to 0.73:1 then I'd go with the 13 or 18. This would give you the option to split the top gear, were as your stock transmission has a very big jump from 9th to 10th gear. This sometimes forces you to turn higher engine RPM to be able to pull hills that you could split the gear with a 13 speed and pull the hill at both the optimum engine RPM for fuel mileage and the Hp needed to do the job.chimbotano and cetanediesel Thank this.
A $3500 price difference won't be recouped very quickly on fuel savings, but if you're going to keep the truck for a while and you've got the budget, you'll like the 13 a lot more.
Whatever you do, once the transmission is out, put it back together with a new clutch and motor mounts. That era FL chassis has some motor mount issues that you don't want to have to fix later.Last edited: Sep 11, 2013
chimbotano and cetanediesel Thank this. -
Makes sure you know what rear gears are in it before changing too much, many companies were getting 10 speed direct with tall gears.
I drove one that was geared not so tall with a direct, and they replaced a 10 speed Meritor with the same thing in a reman. That had to do with parts availability and labor making it too expensive to rebuild the Meritor, but it shifted fine after I broke it in(took a month).
Remanned Eaton was fine from the start, but not as good as a new one in a new truck.cetanediesel and chimbotano Thank this.
