What was this hooked up to?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Todd727, Jun 21, 2022.
  1. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    This is on a Freightliner Columbia that was owned by Ozark. What did this controller work with? They took out any GPS or ELD that it may have connected to.
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,530
    9,733
    Oct 10, 2016
    Brookfield, IL
    Reminds me of the controls for a Qualcomm. I've never seen it where that part wasn't actually part of the whole unit, but that would be my guess.
    Rideandrepair, Todd727 and InTooDeep Thank this.
  4. beastr123
    beastr123 Road Train Member
    2,951
    24,205
    Jan 2, 2014
    Moose Jaw SK CAN
    That is the remote unit for a qualcomm unit. it will read a new message to you while driving when the main unit blanks out while the tractor is moving. Depending on the programming you may be able to do more such as line by line directions as sent by dispatch. That unit is cheap and they seldom remove them as they cover a hole in the dash.
  5. Todd727
    300
    583
    Jun 7, 2021
    Thanks. I'll put the phone holder or some other mount over the hole.
    Rideandrepair Thanks this.
  6. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    Specifically, this is a CV90-J8640-1 Push Button Remote Control Unit. It was an optional accessory for the QC system.
    gentleroger and Todd727 Thank this.
  7. Todd727
    300
    583
    Jun 7, 2021
    Outstanding information. Now to trace the wiring harness and get it out of the truck when I have some spare time.
    Appreciate your help.
  8. Moose1958
    15,296
    33,965
    Dec 17, 2010
    If I understand it correctly there are only 4 parts to that type of QC system. The main QC unit. The hand unit and this part plug into the main unit and the antenna. I would highly recommend not removing it unless you have something to cover that hole with. Trust me. I don't care how much attention you pay to the dash. A hole in the dash that size will cover the inside of the dash with dirt. Dirt and grime can lead to problems with other things in that dash. If you still have a QC just unplug it.
    gentleroger Thanks this.
