What year Cummins should I look for?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Binderdavemays1, Dec 5, 2024.
  1. Binderdavemays1
    Binderdavemays1 Light Load Member
    173
    83
    Jul 30, 2024
    Luebbering Mo
    OK everyone I’m back again, I recently received a rebuild bid for my 79NTC 350 SC it was almost $23,000. That’s not an option and I’m still looking at other bids. My question is I can buy used warrantied engines for around five Grand I would like to put the same year motor as my truck, 84 and a Cummins But not set in stone on that. Please advise your thoughts thank you in advance.
  3. Goodysnap
    Goodysnap Road Train Member
    3,807
    9,288
    Jul 12, 2017
    Warranty on a used engine…..that’s funny.
    What makes you think 23k is expensive for an overhaul? Have you priced the parts needed? Have you seen shop labor prices lately?
    AModelCat and broke down plumber Thank this.
  4. broke down plumber
    4,150
    32,839
    Jan 25, 2024
    You might get 30 days ot until you leave the premises which ever comes first .
  5. Diesel Dave
    9,914
    34,755
    Jan 20, 2010
    Hesperia, Ca.
    For that kind of money, throw a yellow motor in it.
    201 and Binderdavemays1 Thank this.
  6. Star Rider
    Star Rider Road Train Member
    1,842
    20,452
    Sep 23, 2019
    Binderdavemays1 and Diesel Dave Thank this.
  7. AModelCat
    166,453
    $23k is not bad at all for a complete rebuild IMO.
    I built a CAT short block a few years ago and lets just say I was not far off 5 figures between parts and block machining alone.
    Diesel Dave Thanks this.
  8. Binderdavemays1
    173
    83
    Jul 30, 2024
    Luebbering Mo
    You can get a warranty on a used engine. I didn’t say it was a good one and 23,000 is too much money for me.
  9. wore out
    wore out Numbered Classic
    17,815
    224,118
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    That says 30 days on the block and crank. Now that is block and crank only. If it needs a jug, a head and or even never lights as long as the crank isn’t broke and the block will sorta hold a head the rest is yours.
    I understand better than anyone money doesn’t grow on trees. And if it did hell I couldn’t even get a money shrub to take root. Fix this thing once and be done. You can get 10 times more in it trying to get by for less. I don’t mean that in a 23k is a deal on an overhaul sense. I mean it is very much so if the person doing it knows what’s happening. I’ve seen 40k junk overhauls cause the guy that worked for the very reputable shop didn’t give a ####. You gotta do some leg work here, and even then it’s a gamble
  10. Binderdavemays1
    173
    83
    Jul 30, 2024
    Luebbering Mo
    Yeah everything is today, cars, trucks etc
    I have a year to save for this so hopefully I’ll find a good used one for around $5000
    Thanks for the advice I
    wore out Thanks this.
  11. Goodysnap
    3,807
    9,288
    Jul 12, 2017
    A used engine warranty will likely be only to include a similar replacement of the same exact used item. You have to factor in the wrench time to install said engine. If you have to replace it again 2 weeks after you put it in, you’re not gonna be happy camper. Guaranteed the warranty doesn’t include any labor.
    My point is 23k is not a lot of money for rebuilding an engine. And with a 40 plus year old engine there can’t be a huge selection of quality used engines out there. The ones that are out there have likely been setting……. for a long time.
