Whats the harm in going from Mineral to Synthetic
Discussion in 'Volvo Forum' started by biofumes, Sep 17, 2019.
  1. biofumes
    biofumes Light Load Member
    202
    96
    Feb 13, 2009
    California
    As a general rule of thumb, for years, I've been told to stick with what you've been using, but I never really asked anyone why out of respect for those with years of experience.
    A new to us 2013 D13 with 222K miles, was told has mineral 15w-40 weight oil. What are the myths or facts about going from mineral to synthetic? What sparked our interest, was the new 15w-40 T6(fully synthetic) and VDS 4.5 approved.
    https://rotella.shell.com/en_us/pro...5ba16a94dded7f4aea73/shell-rotella-15w-40.pdf
  3. Ridgeline
    22,856
    126,595
    Nothing.
    First do an oil analysis then change it and extend out the oil change, please don't waste oil by doing a 3 or 10k oil change with synthetic.
    Bean Jr., Socal Xpress and buddyd157 Thank this.
  4. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    should be no harm at all. even if you go full synthetic and say you need to add some, you can still use regular oil if that's all you can find at the time you need it. so it goes without saying, carry an extra gallon.
    the oil changes would be longer than before, try to stay at the change interval THAT company recommends.
    also, check the owners manual for thier recommendations, or even the dealership, as things change from the time you first got that truck till now.
    usually too, no additives are needed for "extra protection"
    your engine will experience better starting and quicker lubrication in colder weather, as the main bearings basically sit almost dry (very little oil there) when the engine is off. it's when we go to start our engines,,,,,ALL engines, 4 wheeler or big rig, that the most wear takes place until that oil circulates.
    also, that oil dripping down back to the oil pan will carry away the heat quicker (not that you'd notice).
    many more benefits to synthetics or synthetic blends over conventional motor oils.
    BUT...at a higher cost.
    Reason for edit: spelling
    Bean Jr. and biofumes Thank this.
  5. truckdriver31
    7,001
    8,367
    Sep 18, 2013
    here at wm they go 50k on a syn oil change
    77fib77 and biofumes Thank this.
  6. biofumes
    202
    96
    Feb 13, 2009
    California
    Good info and history to backup this oil brand and weight.
  7. DUNE-T
    DUNE-T Road Train Member
    7,104
    17,336
    May 10, 2015
    Detroit, MI
    Old seals can start leaking oil
    77fib77 and mp4694330 Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,015
    42,143
    Mar 5, 2016
    White County, Arkansas
    I used to run Detriots 25 to 30K before changes. Synthetic was not a problem.
    It does not matter much anymore this oil or that oil provided you run it. The only time I had trouble with fluids was in the older cars I used to own. Some of the modern oils did not do well in there at top end. I recall one employer who used tractor oil in his transmission, it ran with a attitude but it ran.
  9. truckdriver31
    7,001
    8,367
    Sep 18, 2013
  10. truckdriver31
    7,001
    8,367
    Sep 18, 2013
    bring new 1987 359 glider 0 miles
