What's this part for
Discussion in 'CB Radio Forum' started by pete159, May 28, 2022.
  1. pete159
    pete159 Light Load Member
    109
    73
    Dec 6, 2008
    mississauga
    I have a 2019 Volvo vnl the installed antenna coax rottee away, so I bought a Wilson 2000 and will install it on the side mirror bracket. what does this steel part do and do I need to use it for anything. Also what is the part needed to hook up the mic to the swr
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    it's an extension. from the shorter one most likely already screwed into the antenna.
    i never bought a wilson that had one...that must be a "new" piece they stared putting in there
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Can you explain what this means? Tnx.
  5. pete159
    109
    73
    Dec 6, 2008
    mississauga
    I actually found the answer... I just need a short coax cable which I'll plug the microphone into and then the other end goes into the swf meter kind of silly I did not know that at first
  6. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    that's strange, my SWR meter, i needed a coax to go from the back of the CB,(the antenna connection) INTO the SWR meter, and out from there, into the antenna.
    craig_sez Thanks this.
  7. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    I'm beginning to think he has one of those Midland radios that all the controls are built into the michrophone maybe? Or he has a Midland hand held radio that uses a separate cable to hook up an external antenna, I bet that's it.
    buddyd157 Thanks this.
  8. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    Okay, what radio is this that have?
  9. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    if so, i had 2, (different brands) and hated each one...i was a slow learner after the first....
  10. 18 wheels hummin
    18 wheels hummin Bobtail Member
    32
    18
    Dec 8, 2014
    He bought a swr meter that you use to set your swr. It just to set or check. I would leave it hooked up. I believe this is what he talking about
  11. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    Ya I finally figured it out that he left the word "meter" off his original post. Still not sure how or why you would hook a mic to coax. But he said he figured it out, so it doesn't matter.
    Dadetrucking305 Thanks this.
