whats this trailer worth ?
Discussion in 'Ask An Owner Operator' started by BryRylanKW, Sep 1, 2011.
  1. BryRylanKW
    BryRylanKW Light Load Member
    118
    17
    Feb 1, 2011
    cape cod MA
    what do you guys think this trailers worth?
    40ft ravens aluminum frame aluminum deck. winch rail on one side tool box tires all pass inspection brakes are 75% or more. the bad has welds were its been repaired. 40'x102" air ride
  3. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    For what use ??
    BigJohn54 Thanks this.
  4. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    flattened cars,hay,bagged wood shavings,palletized fire wood, anything else that I can find but those are the things I have work for.
    123456 Thanks this.
  5. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    how long has it been sitting, plan to replace some wheel seals, lights, etc. sitting is no good.
  6. king Q
    king Q Road Train Member
    2,880
    3,038
    Jul 26, 2010
    Johannesburg sa
    The thing with aluminium is that it time hardens.
    The older it gets the harder and more brittle it gets.
    The cracks don't seem to bad and don't seem to be in a main stress area.
    If they are repaired properly and proper radius reinforcement gussets put in then I would not worry about the cracks.
    BryRylanKW Thanks this.
  7. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    Ok cool. They said make an offer idk what its worth at all so. I still need to get the year i would say late 80's early 90s.
  8. 123456
    10,555
    5,748
    Oct 22, 2010
    32179
    1200................
  9. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    you cant even buy a dilapidated bobcat trailer for $1200 around here.
    123456 Thanks this.
  10. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    I would offer 15 to 18 hundred, maybe 2 grand. that is what it would be worth to me.. Unit looks good, floor seems ok. 40 foot length is against you:biggrin_25513:. Make sure it is long enough for intended usage and bridge formula weight. Ravens is a good name. They could possibly get more $$$ by junking it out. Aluminum is sky high now,or at least it was.
  11. 123456
    10,555
    5,748
    Oct 22, 2010
    32179
    No auctions up there,
    that's what you need to find !! ??
