Wheel Bearings / Tighten
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Michael 247, Jul 15, 2019.
  1. Michael 247
    Michael 247 Heavy Load Member
    896
    4,718
    Nov 20, 2017
    Dublin Va
    1990 Volvo...Can I tighten the front spindle nut with the tire n wheel still on the truck...if so what foot pounds do I need to set my torque wrench at ??
  3. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Why do you want to do that?
    What kind of nut do you have?
    Did you check the inside wheel seal isn't damp/leaking.
    Search,,
    meritor spindle nut torque.
    Good luck.
    MartinFromBC Thanks this.
  4. xsetra
    5,198
    7,150
    Aug 21, 2011
    I have a stemco Pro Torq nut.
  5. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    Best to check end play, Too tight it will burn up. I’ve heard Volvo’s are more sensitive to do. Don’t know for a fact though. Make sure you use the right specs.
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Either way, make sure you put a jack under the axle for safety!, but no, you don’t need to pull the tire off, just get it off the ground.
    You’ll want the load off the bearings to torque them up.
  7. Michael 247
    896
    4,718
    Nov 20, 2017
    Dublin Va
    When I jacked it up to grease kingpins and shoved on the tire to check for slack in kingpins I figured out the bearing had a little slack ...Took it to local shop and they found Pitts on the bearing so I'm getting bearings replaced on both sides..
    xsetra and MartinFromBC Thank this.
  8. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    They will adjust the bearings for you.
    If you need to do it yourself at some point you have to follow the procedure.
    When they are adjusted correctly you will feel a small amount of play in the wheel. This is because when the bearings get hot they expand. That's why if you make them too tight you burn the bearings out.
    Rideandrepair Thanks this.
  9. Freddy2times
    Freddy2times Light Load Member
    64
    31
    Feb 12, 2019
    general wheel end play spec is 0.001-0.005``
    follow the wheel end procedures from the manufacturer. just remember, ***** you must rotate the tires while preforming the tightening procedure. this will ensure the bearings sit properly on the spindle.
  10. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    The problem I’ve had when using the 2 nut system, is the final torque on big nut tightens it all up, sometimes too much. Must be slop in the threads on inner bolt, or something. I checked out the single nut system, much better set up, torque, loosen and finger tight. Install locking snap ring, finished.
