Wheel seal driver recommendation
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BronsonA14, Feb 25, 2026.
  1. BronsonA14
    BronsonA14 Bobtail Member
    32
    9
    Oct 30, 2024
    A bonus would be if it would do pinion seals also. I feel I’ve done enough wheel seals in the last several years I could probably justify a set. Anyone have any recommendations?
  3. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Pick the seal you want first. Then buy the driver for that brand seal. Most of the brand name stuff will be pricey unless you find it second hand. All of the drivers fit the seals differently. Wheel seal driver will not work on any pinion seals.
    Spicer has a nice driver set for common diff seals. Again each driver will be custom fit to each seal.
    Nothing universal is worth a crap IMO.
    W923, Big Road Skateboard and JB7 Thank this.
  4. BronsonA14
    32
    9
    Oct 30, 2024
    that’s what was afraid of. Problem with that is, I usually don’t have time or want to wait to order a driver after I’ve already waited on the seal to show up
  5. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    If I have to pick I’m going with STEMCO.
    Guardian HP on a rusty axle.
    Voyager on aluminum hub that has a spotless axle.
    Keep in mind the tooling is different for each of the above seal types.
    Tractor, trailer makes no difference.
    If you just pick any old seal from the local parts house, I’d suggest finding a supplier that stocks what you prefer and get the tools to fit those seals. Fleet pride stocks some and can order the tooling.
  6. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    If you're a great customer at one of these places like Fleetpride, they'll give you the tools.
    They usually have stemco seal drivers and wear ring installers in stock, and they give them to shops. Maybe they'll give one if you're a good enough customer
  7. Opendeckin
    Opendeckin Medium Load Member
    502
    1,396
    May 20, 2018
  8. dirthaller
    dirthaller Road Train Member
    1,126
    13,432
    Sep 22, 2011
    Coloratah
    I used to use Stemco GritGuard and have all the tooling to install the two piece seals. They sit in the cabinet and collect dust as I have been using RevMax HD seals the last few years. No tools required but you better clean the spindle way back towards the axle better than you ever have and READ THE INSTRUCTIONS on the RevMax seals.
