Wheel seal problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by john510, Jun 6, 2014.
  1. john510
    john510 Bobtail Member
    24
    Have a mack dump and 2 weeks ago front drive axle passenger side was leaking , pulled off wheels replaced seal and both inner and outer bearings because bearing were pittied.. ran the unit for 2 weeks and noticed seal is leaking again? any ideas what may cause this, could the new bearings be going bad ?
  3. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    I had a dump truck business for 25 yrs and most were macks with 18lb front axle 58lb rears, four things come to mind, did you change the races, if not that's one problem, did you oil up the seal before installing it because if its not lined up correctly you will cut it, is the hub tight enough? or you could have a bad seal.
    Pitting means you caught it in time, did you clean it out completely and make sure no flakes were still left?
  4. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    Check the bearing journals also Eaton axles are good for wear i have had to have several welded.
    Also as stated above you may have messed up the installation. And or didn't have a bearing cup seated completely.
  5. Jackson220
    Jackson220 Bobtail Member
    10
    5
    Jun 6, 2014
    change grease maybe some stuff in there cutting new seal
  6. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Check the vent
    jamespmack and JohnP3 Thank this.
  7. jason6541
    jason6541 Road Train Member
    2,425
    5,367
    Mar 5, 2012
    Omaha, NE
    Did you check spindle where seal rides on it for damage?. Did you use really fine crocus cloth to polish spindle?. And finally did you get seal square in hub?. Don't forget bearing end play should be set with dial indicator at .01-.05 thousanths of an inch. Also be sure vent is clean
    jamespmack Thanks this.
  8. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Check bottom of the spindle for wear where bearings ride.. I replaced both spindles on my front drive axle for that very reason i.e. wheel seals leaking
  9. john510
    24
    Update, pulled it apart and the hub was little loose beat up the seal the new bearing when replaced was not torqued to 200lbs then backed off to insure the bearing was seated properly..
  10. KSC5386
    KSC5386 Bobtail Member
    Oct 14, 2012
    Maryland
    Improper installation will kill you everytime. Its always good to check manufacturers torque specs and procedures if your not 100%.
    Glad it wasnt major.
    John E. Thanks this.
  11. serozhah
    serozhah Light Load Member
    284
    47
    Sep 8, 2013
    how did the new seal work out?
