When to OverHaul?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by billandlori, Sep 23, 2010.
  1. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    What is the best indicator an engine needs an overhaul? Oil samples, mileage, age, etc.?? Rods hanging out of the side is a dead give away!!
    I have heard some guys rebuilding at 700K and some go to 1.6 million.
    Any thoughts??
    Bill
  3. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Do a dyno check...it will tell you all the engines vital signs...oil pressure, blow-by, horsepower, etc.
    Of course if you have an obvious problem like water in the oil, high oil consumption, etc. it's a precursor to a big repair job.
    My CAT is now running after an in-frame due to a perforated liner... should be ready to go tomorrow.
  4. farmerleach
    farmerleach Light Load Member
    80
    28
    Dec 1, 2009
    I'd think in that situation, it would be replace not rebuild.
  5. Krooser
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Well hold on a minute...Drove a '62 freightliner that had the engine blocked patched with fiberglass after it tossed a rod... my boss wasn't about to throw away a perfectly good 220 Cummins!!!!
    heyns57 Thanks this.
  6. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    An oil sample will tell you what is wearing in the engine. If its a cat send an oil sample to them. they will let you know if anything is out of order.
    Keep in mind, just cause an oil sample tells you that you have excessive bearing wear it doesn't mean you need an overhaul. Just roll in another set of bearings and go.
  7. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    There is no magic mileage for overhaul, too many variables. Certainly, excessive blowby is about the best indication of worn rings and liners, and the need for an overhaul. Low power, bad fuel mileage and the engine using a lot of oil in between services are good signs it is time to consider a rebuild. If your engine is approaching the age of an overhaul but still seems to run ok, keep running. Put your money away and save it for when the time comes. I would wait till the engine develops a problem like a failed headgasket, or liner leaking coolant into oil, or something like that.
  8. billandlori
    357
    107
    Sep 5, 2010
    All great info, thanks folks!!
    With my past trucks, I always liked to replace stuff before a failure. It is WAY cheaper to do it when you want to instead of when you have to.
    We were only left on the side of the road once. The mechanic didn't get the oil filter put on right and it fell off and dumped all to oil out in about 20 sec's. Burnt the turbo and not sure what it did to the bearings. This was a company truck and they didn't seem too worried about it. Got a turbo put on and carried on.
    Bill
  9. Heavyd
    7,828
    6,277
    Feb 4, 2009
    We just did a bearing roll for a customer with million km on an ISX. Bearings were still in great shape. I can certain understand preventative maintenance and wanting to fix something before it breaks. But, on the other hand, there are some things that you are just wasting your money on.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    like a wise old man said once (IF IT AINT BROKE DONT FIX IT) had a million 168000 on mine before i rebuilt it.:biggrin_25514:
  11. haystack
    haystack Light Load Member
    177
    22
    Feb 12, 2009
    What would be considered 'excessive' oil consumtion? 1 gallon in 5K miles or 1 gallon in 2500 miles?
