where does antenna mount in 2019 cascade
Discussion in 'CB Radio Forum' started by cuzzin it, Feb 26, 2019.
  1. cuzzin it
    cuzzin it Road Train Member
    3,641
    12,484
    Jan 19, 2008
    Berea, KY
    Hi
    i just got assigned new Cascadia, and can't find where coax comes out .... it has single coax in overhead but no hookups on side, over door, mirror or back of bunk..... anyone know ?
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Its built into the roof. It's a pos if you wanna talk further than the walls of your cab.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Yup, it’s built into the roof. Multiplexed with the radio and cellular antennas for the Diagnostic system if your truck has that.
    Some have okay luck with it, but most mount external antennas and run their own cables. I put mine out the back wall.
    cuzzin it Thanks this.
  5. slim6596
    slim6596 Medium Load Member
    621
    722
    Dec 1, 2015
    Our 2019s and 2020s have antennas on the back of the sleeper. Driver side is CB, passenger side is AM/FM.
  6. cuzzin it
    3,641
    12,484
    Jan 19, 2008
    Berea, KY
    man this truck is junk. pos automatic, and no power.
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Not much better back there unless yer a flat bedder..Might have better luck..
    Both ant are to close to one another and to close to the bunk so you get reflect..
    rabbiporkchop and uncleal13 Thank this.
  8. cuzzin it
    3,641
    12,484
    Jan 19, 2008
    Berea, KY
    update, I'm getting about four miles range out of whatever kind of antennas this has..... good enough i suppose
    Slowmover1 Thanks this.
  9. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    The built-in Hirschmann Thin Film antenna is lucky to get four miles.
    I have a thread from last year on upgrading my new model 2018 Cascadia. Pics, parts, etc.
    At the end I was limited by the other man’s equipment.
    A Uniden 980, RM Italy Kl203 (70W) can fit into cubby and run off the 15A circuit.
    Antennas and mounts are the big thing. See that thread.
    rabbiporkchop Thanks this.
  10. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    It looks like the best solution for that truck would be a 9 foot stainless steel whip bolted to the driver side door.
  11. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    When I was in a '16 Cascadia I averaged about 3 miles and swr was 2.5+, that lasted about a day because when I parked that night first order of business was to purchase bracket,mount,coax, and antenna and setup a good antenna system.
    slim6596 Thanks this.
