Where is the ECM on 2012 Mack.
Discussion in 'Mack Forum' started by TruckerPete1990, Nov 10, 2013.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,381
    Jul 16, 2012
    Bentonville Arkansas
    Where is the ECM at? Trying to do some stuff around it.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I'm not sure of Macks. Usually they are under the kicker panel on the passenger side. It might be under the drivers side kicker panel. You can look under the hood where the main harness passes through the firewall. That will give you a clue. It should be near that inside.
    There's a start until someone chimes in. Happy hunting! :)
  4. TruckerPete1990
    8,623
    5,381
    Jul 16, 2012
    Thanks trying to run some grounds from it making rf noises lol. It's big n silver right?
  5. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Yeah it should be the biggest box. Trucks have like 5-6 ECU's. The ECM is the biggest one. It might be black, plain silver or even blue looking on ebay.
  6. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    It depends on what engine you have really, but I know on the 2010 MP10's the ECM is mounted on the engine, drivers side mid engine block.
    CondoCruiser Thanks this.
  7. TruckerPete1990
    8,623
    5,381
    Jul 16, 2012
    I'm not 100% sure what one. It's a 2012 with cummins auto.
  8. bjytech
    244
    221
    Nov 9, 2013
    The ECM should be mounted to the engine block on the drivers side on a Cummins.
  9. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    bjytech wouldn't that create a heat issue on the chips and components inside it? I've seen cars like that, just wondering.
  10. bjytech
    244
    221
    Nov 9, 2013
    The ECM's can take some heat but most on semi's have some sort of cooling, usually by having a cooling plate with fuel running through it to take the heat away from the ECM.
  11. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    The cat ECMs have been mounted on the drivers side of the block since 95. No cooling block.
