Where is the flasher located??
Discussion in 'Western Star Forum' started by Checkers_86, Jun 28, 2016.
  1. Checkers_86
    Checkers_86 Bobtail Member
    I have an 89 Western Star 4900 and cannot locate where the flasher is at. Any help would be great.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Old time flashers used to be directly inside the unit with which you trigger the 4ways. I don't recall that far back but its to the left under the wheel.
    If you don't find it there, hunt down the main fuse and it should be near or on it.
    bullhaulerswife Thanks this.
  4. Star4900
    Star4900 Medium Load Member
    607
    521
    Mar 16, 2015
    Northern Ontario
    I know on the newer ones it is an electronic box inside the dash pretty much directly behind the steering column. I is the flasher and controls the daytime running lights.
    Had to replace mine and it was about $300 here in Canada.
  5. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Check kick panel too the left of the clutch. That where most older trucks are located. Or under you dimmer switch panel. Remove two screws and should be there.
  6. Naumann
    Naumann Bobtail Member
    I have a 05 western star problems with left blinker doesn't work with headlights on turn headlights off left turn signal works
  7. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    But, right turn works?
    You have a simple wiring problem. Corroded, bad ground.
  8. Jeremiah 6643
    Jeremiah 6643 Bobtail Member
    I have the exact same issue
