Where seal.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRD TRANSPORT, Jan 21, 2022.
  1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    03 peterbilt 379.
    Old Wernner truck.
    Rear seal right side.
    4 time replacing wheel seal in last 3 years.
    Races good, bearings good according to Mechanic.
    Spindle seems to be in great shape almost perfect considering its an 03., 3.55 rears.
    Any advice would be great.
  3. Bro_Dave
    Bro_Dave Medium Load Member
    530
    524
    Nov 5, 2013
    Check the axle vent.
    BoxCarKidd and beastr123 Thank this.
  4. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Axl vent clear of any gunk
    Wash under truck chassis frequently thanks bud.
  5. beastr123
    beastr123 Road Train Member
    2,959
    24,291
    Jan 2, 2014
    Moose Jaw SK CAN
    Pull the vent and manually run a drill bit from bottom to top.
    Not often the vent will plug at the bottom and the cap is free and loose.
    BRD TRANSPORT Thanks this.
  6. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Just a few things I can think of.... What kind of seal you using? Are the races tight in the hub? Before taking the axle nuts off can you move the wheel any? (When I do a brake job on a truck I always push on the top of the wheels after I jack the axle up to test for play). Are the spindle nuts torqued properly? Have you checked for cracks in the hub itself? (I have seen this before as well) Is the mechanic cleaning the spindle and hub area really good? Is there any damage to the spindle? (I have seen hairline cracks in axles near the spindle as well).
