Where to tap into for lights?
Discussion in 'Kenworth Forum' started by TruckerPete1990, Dec 13, 2022.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
    Adding some lights to my T680 on my sleeper. I'm trying to find where the factory is hooking in for these lights.
  3. Concorde
    Concorde Road Train Member
    5,657
    20,144
    Jun 29, 2016
    West Melbourne Florida
    You must have a spare switch or two on your dash.. I did on my 2014 T-680.
  4. TruckerPete1990
    8,623
    5,383
    Jul 16, 2012
    I don't I have one which I use for my heated wipers.
    Concorde Thanks this.
  5. TruckerPete1990
    8,623
    5,383
    Jul 16, 2012
    I watched this video but I can't find where they tapped in at. Was thinking worst case I could tap into the wire coming out of switch but not sure if it will cause issues with voltag on the newer trucks.
  6. The_Kenworth_w990
    The_Kenworth_w990 Bobtail Member
    19
    10
    Dec 20, 2022
    You Can Always Add A Relay And Wire Them To Come On With The Rest Of Your Lights If You Want. The Switch You Use To Turn Your Marker/Running Lights Will Have A Switched +12v Out, Add A Relay To Prevent Overloading The Circuit. You Can Always Add A Switch To Run Them Independent Instead Of OR With The Factory Switch Depending On Your Understanding Of Electrical Systems.
  7. TruckerPete1990
    8,623
    5,383
    Jul 16, 2012
    Would a relay even be needed? I was thinking of just splicing into the marker switch its just those bullet leds lights.
  8. The_Kenworth_w990
    19
    10
    Dec 20, 2022
    Well It's Peace of Mind. You Might Get By Without One (Very Likely) But If One Of Those Little Lights Shorts Out It Shorts Your Whole Factory Circuit. The Relay Provides A Form Of Isolation From The Factory Circuit Per Say. Another Thing To Think Of Is A Year Or Two Down The Road If You Decide To Add More Lights (Or If You Sell The Truck And New Owner) Decides To Add Lights Unaware Of How They Are Wired, It Could Overload That Circuit. It's A Cheap Form Of Insurance To Separate The Aftermarket Lights With A Relay And Fuse, And Makes Future Installs Easier.
    Advantages Of Adding A Relay AND Fuse:
    (1) - Overload Protection.
    (2) - Isolation From The Factory Harness And Electronics Which Are VERY Sensitive/Fragile.
    (3) - Less Risk Of Blowing The Trucks Fuse And Killing Factory (DOT REQUIRED) Lights At The Same Time.
    (4) - Future Peace Of Mind Installing Additional Lights Knowing The Circuit Is Meant To Handle
    Additional Lights If You Choose And Not Having To Figure Out What Wire To Tap Into.
    Potential DISADVANTAGES Of NOT Adding A Relay AND Fuse.
    (1) - Short Circuit Of Added Wiring Or Light(s) Blowing The Factory Fuse, Killing Factory Lights.
    (2) - Possibly Overloading Wires And Melting Insulation On Factory Harness.
    (3) - Overloaded Circuit Causing Damage To Electronics In The Truck Like The BCU (Body Control Unit), ECM, ETC. Short Circuits And Overloads Are Extremely Unpredictable And While Not Likely Could Cause EXPENSIVE And EXTENSIVE Damage.
    Again, You Might (Likely) Would Be Fine Without, But For Under $20 For The Relay, A Fuse Holder, Fuse, And Some Female Spade Terminals Its CHEAP Insurance And Peace Of Mind.
