Which Manufacturer?
Discussion in 'Questions From New Drivers' started by Dave_in_AZ, Dec 7, 2020.
Which manufacturer?
This poll will close on Feb 6, 2040 at 7:29 AM.
  1. Paccar products
    8 vote(s)
    28.6%
  2. Volvo
    20 vote(s)
    71.4%
  1. Dave_in_AZ
    425,182
    Which manufacturer do you park next to more often that has the compressor kicking off every 15 seconds???
    Lumper Humper and bzinger Thank this.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    When I go to sleep for the night, I don’t park next to other trucks.
  4. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    Pull the cab off, and they're all the same underneath. You should change your poll choices to Bendix, Wabco and Kysor.
  5. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Volvo !!
    It’s always the white Volvo from Chicago with the smashed up hood.
  6. Hulld
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    It’s more about the drivers who refuse to repair the air leaks on their truck than it is about air dryer manufacturers.
    It really takes a special kind of driver to drive around in a truck that has a big enough air leak that the air dryer needs to cycle every 10 minutes.
  7. mitrucker
    mitrucker Road Train Member
    5,488
    10,317
    Dec 15, 2010
    Lapeer, MI
    What about the crappy old Columbias and Centurys??? They are even more common for doing that IMHO.
    racemaxx24, 650cat425, Hulld and 4 others Thank this.
  8. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    Mine was popping every 45 seconds! I figured no way was it an air leak at the fan, because I replaced the fitting and cut new line. So I checked the signal line from the governor, and sure enough, the governor was bad. Replaced it, still popping off. Since I was still convinced it couldn't be the fan, I figured my unloader valves were stuck. Welp, no rebuild kit for my compressor apparently, and no head either. New compressor is a thousand bucks...
    So I decided to crimp my fan air line just to see what would happen. Problem solved. I ordered a rebuild kit for the fan clutch, and it turned out to be a busted O-ring. Man, you would not believe what a difference it makes having a fan that works correctly, lol. And now my dryer hardly ever pops.
  9. bryan21384
    bryan21384 Road Train Member
    15,736
    34,295
    Sep 18, 2009
    Memphis, TN
    I've noticed that most with Freightliners actually. Oftentimes I'm dead to the world at night, or the reefer unit drowns out other sounds. My buddy had a freightliner cascadia he leased with CRST, and when he would call me, i could hear the compressor through his phone. It was so abnormally loud.
  10. bryan21384
    15,736
    34,295
    Sep 18, 2009
    Memphis, TN
    I agree wholeheartedly.
  11. Dave_in_AZ
    425,182
    They were excluded because the other two outnumber them 50 to 1.
    Vic Firth, Hulld and bzinger Thank this.
