Whistling noise
Discussion in 'Ask An Owner Operator' started by Celina, Feb 9, 2020.
  1. Truckers Report Jobs
  2. PE_T
    PE_T Road Train Member
    Maybe it’s an air leak coming from the fan clutch or the airlines for the brake pedal.
  3. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Turbo
    PE_T Thanks this.
  4. Trucker Jon
    Trucker Jon Bobtail Member
    39
    50
    May 27, 2018
    Are you losing boost? That sounds like a boost leak.
  5. Spyro2112
    623
    433
    Mar 17, 2018
    Actuator on turbo
  6. Spyro2112
    623
    433
    Mar 17, 2018
  7. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Leak on intake manifold or charge air cooler. Learn how to check the system with a few items. 5 inch pvc end cap, hose clamped on intake tube off of the turbo drill holes to screw in pressue gauge and valve for adding air like a metal tire valve stem, also block end of tube at the intake manifold with 5 inch pvc cap, secure with hose clamp, pump air into system 20 lbs, see how long it takes to leak down. You have a leak somewhere. If you can't find it, hook up the end to intake manifold and repeat. Could be leaky gasket on manafold or hose going to air compressor. Good Luck.
    PE_T Thanks this.
