who knows what it is? Help!
Discussion in 'Freightliner Forum' started by Metrysha, Oct 27, 2018.
  1. Metrysha
    Metrysha Bobtail Member
    20
    Sep 7, 2018
    Why? What happened?
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    It's flex pipe clamped by V clamp to the aftertreatment injector.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If you are about stains on the pipe could be drops from cab bottom or fuel with soot from aftertreatment injector. Check the gasket under V clamp.
  5. Metrysha
    20
    Sep 7, 2018
    thank you very much guys. :rolleyes: I hope it is easy to fix. I will try when I stop
  6. Rideandrepair
    17,561
    56,893
    Aug 8, 2015
    Looks like oil but probably fuel. Try to tighten clamp.Have you been letting it low idle?
  7. Metrysha
    20
    Sep 7, 2018
    thank you very much for the answer. Yes, the clamp is fine, I checked it today. Now I’m on the road I can’t say about engine idling right now
    Rideandrepair Thanks this.
