Who's using dash cams and what kind?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by outerspacehillbilly, Mar 16, 2011.
  1. outerspacehillbilly
    outerspacehillbilly "Instigator of the Legend"
    4,349
    2,431
    May 28, 2009
    The Who's Your State
    Anybody here using a dash mounted cam in your truck? I'm thinking about getting one for my new truck but don't have a clue what kind to get. I have found some as cheap as $59 but figure you'd be getting exactly what you pay for a piece of $59 junk. I don't want anything "professional" but something that will take a decent video.
  3. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    I use a Sony Handycam DCR-SX44 on a Delkin extended suction cup mount. Camera is light weight and decent quality. There is an HD version available but I wasn't interested in HD, my camera is more of an insurance policy. Picked the camera up at Walmart, uses SD or Memory Stick cards and ordered the mount through Amazon.com
    BTW I will only use Sony cameras. I have ordered some of those cheap dash cams and they are junk. One that came with it's own mount would overheat in the sunlight and shut off. What good it that? The reason I only use Sony cameras is past experience with sports videography. For the money, the Sony CCDs provide better color and clarity. There motion adjustment (steady shot) works very well adjusting for the suction cup mount too.
    outerspacehillbilly Thanks this.
  4. outerspacehillbilly
    4,349
    2,431
    May 28, 2009
    Thank LB. That's exactly the kind of info I'm looking for. Do you remember how much that model cost you? I'm mainly wanting it to CMA but also you see things happen and later think if only I could have gotten a picture or video of that it would have been awesome! :biggrin_25525:
    BTW does that model used Infrared also for night vision? Is it clear enough to read license plates?
  5. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    It is clear enough to read license plates if it's zoomed in a bit (it is pretty wide angle zoomed all the way out) and does well at night with no night shot built in. IIRC it cost around $160, and better models go up from there. There is also a model with a built in hard drive for around $300. The only thing I don't like about it is the screen has to be open for it to record so I just flip it around so the screen isn't shining in my face going down the road. I use a $40 plug in inverter to keep it charged while recording.
  6. outerspacehillbilly
    4,349
    2,431
    May 28, 2009
    Great thanks for the info. I'll definitely check it out.
  7. 935mseop
    935mseop Bobtail Member
    6
    Saskatoon, Sk
    Do a search on acuity compliance they have a good little dash mount camera works perfect in trucks
  8. flood
    flood Road Train Member
    4,169
    4,053
    Dec 25, 2010
    this is the setup we have in our truck
    works well
    this what the cam sees
    i can zom and pan it at will
    ram mount makes a mount for cameras that mount on motorcycle handlebars, works great to mount on the grab handle,
    Moon_beam Thanks this.
  9. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    DieselBoss has been doing a lot with Dash Cam's. Check out on his website.
    Mark
    bbqguy Thanks this.
  10. Travelinman
    Travelinman Medium Load Member
    420
    127
    Mar 22, 2010
  11. Travelinman
    420
    127
    Mar 22, 2010
