Whose the Cat guru here?
Discussion in 'Ask An Owner Operator' started by Marmon110P, Nov 27, 2022.
  1. Marmon110P
    Marmon110P Light Load Member
    192
    189
    Feb 24, 2019
    Ive got a 3405E (5EK) that I inframed myself last december. Everything was redone with IPD parts and Im currently running in the 800HP range. Everything was great till about 3 months ago, it started using oil. A month later I blew the head gasket between #2 n 3. I realized then that the oil gallery grommets were not in the spacer plate, so I figured that was the issue. I put er all back together and now its still using about a gallon of oil every 500 miles (not a misprint). No leaks anywhere. Today I took the exhaust manifold off to see if there was a wet hole and #2 is definitely wet and #6 is showing signs, but not actually wet. What is the next step in diagnosing this?? PS - the block was not decked nor the head touched other then new injectors and cam at the time of inframe. Could this likely be valve guides leaking?
  3. exhausted379
    2,246
    32,225
    Dec 1, 2013
    Woreout
    Big Road Skateboard Thanks this.
  4. wore out
    wore out Numbered Classic
    17,329
    215,218
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If it’s valve guides you will have smoke after idling and smell burnt oil when you pull out after idling. You will also see a lot of carbon on the springs with bad guides. It’s from the cylinder pressure bypassing the guides and cooking the oil on that spring.
    My money is on a broke ring
  5. Marmon110P
    192
    189
    Feb 24, 2019
    OK, so I guess the next step is to pull the head and then pop those 2 out and see whats what? I guess I might as well send the head in to have it resealed also?
  6. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    How old is the air compressor, it could be using the oil.
  7. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Would a broken ring leave marks in the liner or not necessarily?
    If you are gonna pull it apart I'd definitely get the head checked out and check liner protrusion
    wore out and Diesel Dave Thank this.
  8. Marmon110P
    192
    189
    Feb 24, 2019
    I replaced the compressor when I did the head gasket about 2 months ago since I thought that could be my oil consumption issue, and it was leaking some out the head anyways. Im gonna pull the pan and head tomorrow and if theres enough daylight, get the #2 n 6 pistons pulled to see whats up with the rings and liner walls
    Mnmover99 Thanks this.
  9. 77fib77
    77fib77 Road Train Member
    11,666
    76,984
    Jul 7, 2010
    St Louis
  10. wore out
    17,329
    215,218
    Jun 5, 2013
    99 percent of the time it will leave a double ring groove at the top. It should also have a heart beat when you look at blow by coming out of fill tube. Sometimes you can feel it putting your hand over fill tube but not always
    lester and 77fib77 Thank this.
