Why are these lights continuously on and flickering?
Discussion in 'Questions From New Drivers' started by xzmpt, Aug 14, 2024.
  1. xzmpt
    xzmpt Light Load Member
    93
    83
    Nov 22, 2022
    I was driving and noticed these lights were on and flickering despite the actual switch being off. When I turn the switch on, they just get brighter. It’s on both sides as well. Also, when I turn on my headlights they get a bit dimmer. What’s going on?
    austinmike Thanks this.
  3. Mysen1
    Mysen1 Bobtail Member
    16
    19
    Jun 27, 2014
    To get a meaningful answer to your question It would probably help a lot if you provided make, year and model.
    77fib77, tscottme and xzmpt Thank this.
  4. xzmpt
    93
    83
    Nov 22, 2022
    It’s a 2021 Kenworth T680
    tscottme Thanks this.
  5. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Are both doors completely shut? Open and close the passenger door just to be sure. If they are, go into the instrument cluster menu, find the provision for the interior lights to be on when the doors are open, and turn that off. You’ll lose your interior lights when the doors are open, but, that should kill those lights.
    I suspect, your BCM (Body Control Module) isn’t happy. If you can disconnect battery power, that might reset the BCM.
    Given this is a POS PACCAR product, get used to unexplainable BS with the electrics. These trucks truly are garbage.
  6. tscottme
    tscottme Road Train Member
    My KW T680 needed the passenger and driver door to be slammed very very hard.
    Those symptoms could be from a door almost closed.
    Also those light may have switches to turn then on & off when engine is on or off. Try using the on/off switch built into the lights to turn them off.
    Once you start the engine those lights will become brighter because of the increased voltage coming from the alternator, versus the battery voltage when engine is off.
    ducnut and austinmike Thank this.
  7. Moosetek13
    Moosetek13 Road Train Member
    15,004
    19,065
    Nov 1, 2010
    Burnsville, MN
    My Cascadia has that 'door almost closed' thing, but it toot-toot-toots the horn until I slam it shut.
  8. austinmike
    141,269
    Door ain't shut
  9. AModelCat
    165,091
    Check the door switch. Seen them fail on the older B cabs.
  10. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    On these, only the round light is switched at the fixture. Even then, with CAN bus systems, you’re not cutting power to the light; you’re only sending a signal to the BCM you want to turn off the light. It’s a stupid way to control truck electrical systems.
  11. Cali kid
    Cali kid Road Train Member
    1,804
    2,547
    Feb 15, 2011
    IE, CA
    Here’s a trick for all y’all That never drove a T-800 that sealed like a tank. Crack your windows before shutting the doors that way you don’t have to slam the #### out of them. Only way we could get them to shut completely back in the day.
