Why automated transmissions skip gears.
Discussion in 'Questions From New Drivers' started by PianoManCJS, Feb 26, 2026.
  1. PianoManCJS
    PianoManCJS Light Load Member
    147
    150
    Jan 13, 2025
    Aside from Google's AI generated answer, what is the reason modern automated semitrucks jake upshift and skip gears? The Freightliner Cascadias I've been in skip from 1-4-7-9 then 10-11-12. Kenworths I've been in I notice use every single gear...1-2-3-4-5-6-7-8-9-10-11-12.
    Trucker61016 Thanks this.
  3. FullMetalJacket
    FullMetalJacket Road Train Member
    3,305
    5,523
    Oct 16, 2013
    Vagrant
    Can only answer on Cascadia.
    In the first bit of driving the transmission/computer will teach itself your weight/terrain & adapt its shifting as it deems appropriate.
  4. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    Two different transmissions, but the Freightliner sounds to be set up for fuel mileage.
    There are a couple different shift strategies that can be used.
    Lonesome, Oxbow, Bean Jr. and 2 others Thank this.
  5. tscottme
    tscottme Road Train Member
    Automatics are trying to save fuel. If your truck has a setting, AND THE ECM & COMPANY allow it, put it into manual mode if it bothers you. I found I could hold the shift paddle up or down, not just press and release it, but hold it all the way up or all the way down, and that would stop skipping of gears or the early shifting into an inappropriate gear. I would use this technique when approaching a climb or during a climb so the transmission wouldn't skip into the wrong gear early and kill my momentum. Maybe that's a tanker thing and me anticipating the surge helping/hurting the transmission's flat-land shifting plan.
  6. FullMetalJacket
    3,305
    5,523
    Oct 16, 2013
    Vagrant
    Yep, all in the programming.
    Oxbow Thanks this.
  7. Saltyoldone
    Saltyoldone Light Load Member
    189
    531
    Jun 16, 2019
    Boise
    My company has set the Mack truck in eco mode so it starts in 4th then jumps to 10, 11, 12. I’ve killed it on off ramps because it doesn’t have enough power to pull out of an inclined stop sign and I have no way to manually shift it down from 4th.
    I’m sure the company has paid more for mechanics and tow trucks to pull me out of construction sites then they would have on diesel if they’d put it in normal mode or allowed me to manually shift down when required.
    I get paid by the hour so I have no problem waiting on a tow/mechanic.
    Lonesome and Toomanybikes Thank this.
  8. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    On Freightliner if loaded light no reason to go thru every gear if the engine can pull and skip a gear. They transmission can control the engine and it know if the engine can skip a gear and keep pulling. They also have a terrain mapping they claim. So the truck know how big the hill is. It also can sense the load on the truck and can skip gears when possible.
    when the truck manufacturer makes the engine and transmission they can talk to each other and work as one. The first generation automatic could not and they had to go thru every gear. They also had trouble pulling hills because and would keep shifting up and down because engine could not pull the next gear.
    Today’s truck like Freightliners can see the hill and know how long it is and senses the load. They it can change the shift point(rpm) depending on all that information.
  9. Grumppy
    3,234
    11,402
    Dec 11, 2010
    West Monroe, La
    Our Volvos also start in 4th, 6, 8, 10, 11, 12. I agree, its just how its programed and they have our manual mode disabled.
    Saltyoldone, prostartom and Lonesome Thank this.
  10. BlackjackCo
    BlackjackCo Light Load Member
    155
    644
    Mar 29, 2024
    Both my 2025 & 2026 Kenworth W990's with Easton TX-18 transmissions will skip gears as needed and often in the lower gears. On High Jake when you let off gas it sometimes drops 2+ gears as needed to slow you down. It skips more when empty or bobtail. And we do have manual mode which I use to prevent dropping gears when using medium and high jakes coming off mountain passes just holding it back not trying to stop
