Why buy DEF in a box?
Discussion in 'Experienced Truckers' Advice' started by tscottme, Oct 30, 2019.
  1. tscottme
    tscottme Road Train Member
    I know modern trucks need DEF. I'm not asking about why DEF is needed. I'm asking why buy DEF in a box at a truck stop, which is usually more expensive than at the pump? If your answer is "so you don't run out" the question remains why not just buy it at the pump. On my truck I add DEF every other time I fuel the truck.
    Is it for farm customers? That or it's for flying saucers is all I can think of.
    Thanks
    Lepton1 and Flat Earth Trucker Thank this.
  3. AModelCat
    164,747
    Not always easy to take your skid steer or mini ex to the fuel island.
    RubyEagle, kylefitzy, stwik and 6 others Thank this.
  4. wis bang
    wis bang Road Train Member
    3,455
    4,099
    Jan 12, 2011
    Levittown, PA
    diesel 4 wheelers need it too!
    thelushlarry, snowwy and tscottme Thank this.
  5. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    I think it's more for light duty trucks , pickups and what not . I know my TDI Jetta didn't need def , best car I ever owned .
    tscottme Thanks this.
  6. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,163
    Jun 3, 2018
    Not all fuel stops have DEF at the pumps .
    starmac, Dennixx, Tb0n3 and 2 others Thank this.
  7. Cattleman84
    Cattleman84 Road Train Member
    10,015
    71,497
    Nov 1, 2017
    The Sticks, Idaho
    The DEF pumps have a bad tendency to freeze in the winter... The boxed stuff is usually kept inside. Better to pay more for a few gallons than to run out because the pump was froze at your fuel stop.
  8. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i was lucky, since we had Penske trucks, i could get all the boxes of DEF i wanted for free. so i'd take 2 boxes, and each night when i fueled up, i used maybe nearly an entire gallon each time.
    then the truck stop installed the DEF pumps. but i still had at least one box in the truck, "just in case" the pump at the truck stop did not work, and yes, that did happen a time or 2.
    then my former employer got onsite fueling, and they had DEF.
    but walmart (i believe??) or many auto parts stores sell DEF, and i have seen them priced about the same as the truck stops too in fact.
  9. jdimes
    jdimes Medium Load Member
    559
    549
    Apr 22, 2011
    somewhere, usa
    Up here in the northeast the Pilots/FlyingJ try to insulate the pumps as best they can during the winter months but sometimes they still freeze up good to carry a box or two on the truck.
  10. 062
    062 Road Train Member
    6,330
    33,971
    Oct 20, 2013
    Is that anything like wine in a box? @thelushlarry can we get a ruling :rolleyes:
  11. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    If you drive a lot on back roads you may not see a def pump for a while
