Why do i keep blowing turn signals?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Russian Rabbit, Feb 2, 2020.
  1. Russian Rabbit
    Russian Rabbit Road Train Member
    1,715
    1,635
    Jan 3, 2016
    Why do i keep blowing the left turn signal? We put a new fuse in (i think?), then the next day it does it again, then a new fuse, then blows again, etc. etc.
    2006 volvo vnl 60.
    Thanks.
  3. Russian Rabbit
    1,715
    1,635
    Jan 3, 2016
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Probably have a short in one of them or in your piggy tail
    Russian Rabbit Thanks this.
  5. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    becuase its an old truck and you have a short somewhere. You are gonna have to trace your wires. . i have an old truck, i wound up just replacing all my wires and harnesses. to avoid that headache for another 20 years or life of truck. I went a little extreme but you gonnnahave to find out where the wire is rubbing through or grounding out. Get you a multimeter and youtube on how to use it to find a short
    Russian Rabbit and Bakerman Thank this.
  6. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Start at the light and work your way back looking for exposed wires.
    Russian Rabbit and Chubby Fly Thank this.
  7. MOBee
    MOBee Road Train Member
    1,774
    10,159
    Apr 27, 2014
    Out of blinker fluid?
  8. Russian Rabbit
    1,715
    1,635
    Jan 3, 2016
    UPDATE:
    It turns out it had nothing to do with the fuses; The mechanic put, (i'm ASSuming) dielectric grease on the light bulb contacts and the lights/turn signals all work fine now.
    He's thinking we will have to order new light sockets soon. i'm not sure how a non-moving electrical part can "wear out," but ok.......
  9. Russian Rabbit
    1,715
    1,635
    Jan 3, 2016
    P.S. This joker has 713,000 miles on it. Runs well, i think.
  10. Opus
    132,317
    Make sure you're using the correct bulb because they make more than one. I made that mistake. Look at your other one and make sure it matches.
    Might be as simple as that
  11. mud23609
    mud23609 Medium Load Member
    652
    1,444
    Mar 9, 2015
    Vibration over time. Even though they fit tight they do have some tolerance. And overtime it gets sloppier from it moving ever so slightly with road vibrations, potholes and the like.
