Why do Volvo cabs come off chassis so easy
Discussion in 'Experienced Truckers' Advice' started by InTooDeep, May 18, 2022.
  1. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
  3. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    First time I'm seeing that kind of damage to a cab.
    It should have hold better. And protect the driver better.
    InTooDeep Thanks this.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    They had to start building them out of plastic to cover the added tare weight of all the coffee makers, stoves, refrigerators, tv’s and home entertainment systems these people all seem to need to have with them. That’s why it looks like somebody rolled a motor home when they crash one.
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
  6. SmallPackage
    5,818
    18,639
    Dec 20, 2019
    Marion Texas
    Cabs come off a lot these days on all makes due to them not having solid mounting points anymore. Cost of safety for having air ride. Even back in the day Petes had a 3 point mounting system with two bolts in front one at each corner and just one bolt in center rear. White Motor products from which North American Volvo came from had four point mounting.
    If you ripped a cab off a truck back then you were a legend because you only had less then a 1% chance of it happening even falling down a cliff.
  7. Arctic_fox
    4,553
    25,868
    Sep 16, 2016
    I mean your not wrong...that said my fridge, laptop and little achohol stove are more then enough to keep me content and only add around 40 pounds.
    As for volvas, its because so many people cut holes in the floor and all the acidic curry and pickled everything waste eating away at the supports.....
    D.Tibbitt Thanks this.
  8. TheLoadOut
    TheLoadOut Road Train Member
    2,435
    11,658
    Nov 6, 2019
    Well, you're not supposed to crash them in the 1st place.
    striker and Rubber duck kw Thank this.
  9. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    There is that, but sometimes you attend someone else’s crash just ‘cause you were handy. They should come with a little bit of survivability for those instances to protect the innocent.
    wis bang, ncmickey, striker and 2 others Thank this.
  10. D.Tibbitt
    157,291
    Lmao!!!:laughing3:
    Cattleman84 Thanks this.
  11. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    About 10 yrs ago, Schneider Frieghtshaker sleeper was involved in a 5 car on I-76 outside Brighton, Co, the cab ripped loose and ended up sitting upright in the median about 70' from the frame and engine
