Why Does Light Make Migraines Worse?
Discussion in 'Driver Health' started by Baack, Jan 11, 2010.
  1. Baack
    Baack Road Train Member
    15,294
    10,174
    May 24, 2007
    Wisconsin
    http://www.wisn.com/health/22204300/detail.html
    GAPrincess and Swaps Thank this.
  3. Swaps
    Swaps Heavy Load Member
    757
    361
    Jan 10, 2010
    Minnesota
    a migraine headach is when the blood vessels around the optic nerve (the big stringy thing that connects the eye to the brain) increase in pressure and literally squeeze the nerve. Thus making extremes in vision (aka, bright lights) very painful.
    I get migraines. Thankfully mine are manageable. Usually if I catch it quick enough I can pop a few excedrine and I'm good to go. But if I let it go then I'm done for. The only thing I can do is try to take a nap and sleep it off. The pain gets so intense that it's not uncommon to vomit. Thankfully, it hasn't gotten that bad for me recently.
  4. socal
    socal Medium Load Member
    574
    348
    Feb 18, 2008
    Los Angeles CA
    I get Migranes also Typically Severe pain Behind my right eye. Sometimes if I catch it Early I will take a cold can of soda and hold it to my eye for relief, if not sleep is the only way.
  5. Swaps
    757
    361
    Jan 10, 2010
    Minnesota
    The reason excedrine works so well is because of the amount of caffine in it.
    The caffine opens up the bloodvessels and reduces the pressure.
  6. Mrs T
    Mrs T Road Train Member
    1,625
    1,500
    Aug 5, 2008
    planet earth
    Uuuhhh,, thats not quite right.
    Caffeine has no direct effect on the blood vessels, though it does raise the pulse rate, therefore pushing up blood pressure, as the heart is pumping more. It also raises intraocular pressure, which is the pressure within the eyes.
  7. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,290
    Dec 15, 2008
    Rochester, NY
    My headaches get worse when exposed to sound. At the right pitch, it becomes pure hell for me! Oddly enough, it is the same pitch of my wife's voice when she is rattling off her "honeydew list" and my headache gets so bad, that all I can do is sleep it off! ;-)
  8. Mrs T
    1,625
    1,500
    Aug 5, 2008
    planet earth
    yeah right?!:biggrin_2552:
    Ask your wife to write the list down instead. :biggrin_25514:
  9. truckerdave1970
    2,987
    3,290
    Dec 15, 2008
    Rochester, NY
    Boy, am I glad my wife wont be reading this! I got a good gimmick going and I got her fooled and you want to mess it up for me? Thanks alot! With friends like that...!
    Just kidding, BTW.
    Mrs T Thanks this.
  10. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    I found that for my migraines (bad enough I have had to go to ER for shots before and also have prescriptions for the bad ones) if I catch it early enough a beer with 2 tylenol will keep it from getting to the usual extremes.
    Now for those of you not medically aware Acetaminophen (tylenol) is bad on your liver, when taken with alcohol the damage done is dramatically increased. So yea this may not be healthy in the longrun, but when you get the kind of migraines that run in my family you say screw the longterm at that point.
  11. Mrs T
    1,625
    1,500
    Aug 5, 2008
    planet earth
    You would need to take eight or more acetaminophen every day with alcohol to do real damage. As long as it just occasional for migraines, and you drink non-alcohol afterwards, it should not do much harm. Safe limit is 8 tablets in 24 hours, if they are the 500g tablets. Hope that helps!
    Baack Thanks this.
