Why is it sometimes impossible to shut the trailer doors on sloped ground?
Discussion in 'Experienced Truckers' Advice' started by expedite_it, Sep 30, 2022.
  1. expedite_it
    expedite_it Road Train Member
    1,646
    865
    Sep 8, 2012
    Several times in my career I have not been able to shut the trailer doors on sloped ground, but i was able to shut the trailer doors when i moved the trailer to flat ground.
    I know that when the trailer is lower than the tractor on sloped ground, gravity is pulling the trailer doors down. But gravity is pulling the trailer down too. So I would think the trailer being pulled down too would cancel out the effect of gravity on the trailer doors.
  3. Milr72
    Milr72 Medium Load Member
    585
    1,440
    Dec 16, 2011
    S W Missouri
    Your trailer is twisting just enough that the door latches won't line up.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,034
    Dec 31, 2010
    Washington, PA
    Has happened to me many times. Make and model always different so couldn’t blame one type.
  5. expedite_it
    1,646
    865
    Sep 8, 2012
    Why don't the trailer doors "twist" with the trailer?
  6. InTooDeep
    4,981
    37,365
    Jan 17, 2016
    Carmichael CA
  7. Magoo1968
    Magoo1968 Road Train Member
    2,139
    5,702
    Mar 18, 2021
    St Malo mb
    The rear frame that goes around the trailer doors is weak and allows trailer to flex . Often all you have to do is put your hand under latch and push up your latch for it too catch.
  8. lester
    2,959
    8,099
    Jan 2, 2012
    NW, Iowa
    Geometry completely lost to you huh?
    Not to be rude or anything, are you originally from American or somewhere else?
    Speedy356, Hammer166, Kyle G. and 8 others Thank this.
  9. Concorde
    Concorde Road Train Member
    5,734
    20,511
    Jun 29, 2016
    West Melbourne Florida
    As others have said.. the surface you parked on is causing the trailer to twist. I’ve had it happen many times. Sometimes just pulling ahead a couple feet resolves the problem.
  10. expedite_it
    1,646
    865
    Sep 8, 2012
    Why would the rear flame flex on sloped ground but not on flat ground?
  11. Dennixx
    Dennixx Road Train Member
    4,600
    14,843
    Feb 13, 2010
    twin cities
    In my best Alan Ludden voice..
    "Today's password is ....Flex"
